script file for running fluent on linux cluster
Old   January 11, 2006, 08:27
Default script file for running fluent on linux cluster
Worth
I'm using the following script to run a single processor fluent job on a linux cluster machine using Sun Grid Engine:
#!/bin/bash #$ -S /bin/bash #$ -cwd export PATH=$PATH:/usr/global/Fluent.Inc/bin:$HOME export FLUENT_ARCH=lnx86_glibc22 export LM_LICENSE_FILE=7241@egr8-w2k export FLUENT_INC=/usr/global/Fluent.Inc /usr/global/Fluent.Inc/bin/fluent 3ddp -g -i run1.jou >& run1.out
Batch jobs work fine on the main processor (linn1). However, when I use the above script to send to another processor on the cluster via Sun Grid Engine I get a directory path error. It appears that the other units of the cluster can't find the software. What should I do?
Thanks for any and all help. Worth
Old   January 11, 2006, 08:45
Default Re: script file for running fluent on linux cluste
mAx
Hi, the command to run fluent on a cluster should be like: fluent 3ddp -g -pnet -i run1.jou >&run1.out& where -pnet is linked to the RSHD communications software. If you are using MPICH then you should use -pnmpi If you are using MPI/Pro then you should use -pvmpi
Old   February 9, 2012, 11:31
JOERIK
joerik is on a distinguished road
Send a message via Yahoo to joerik Send a message via Skype™ to joerik
i actually did try to run the same simulation i had ran on a windows environment on the clusters with the following command line
fluent 3ddp -t8 -cnf=/home/name/node -g -i pipe_sf.jou > result.out
but got a lot of error messages.
The /home/name/node is the file path name on my computer and the pipe_sf.jou has the script to read the case and data file with a number of iteration.
My initial problem is that the case file did not even read to the end
joerik
joerik is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Fluent on Linux Cluster george FLUENT 0 August 11, 2006 04:57
