how to set BC for compressible flow target mass flow rate
Old   April 3, 2012, 16:12
Default how to set BC for compressible flow target mass flow rate
Guan
foolboy007 is on a distinguished road
I have a T shaped geometry. One inlet and two outlets.
Total flow rate is 500 slpm. The flow ratio for the outlets is 9:1.
I am using compressible flow to solve the flow.
inlet: mass flow intlet
outlet: pressure outlet with target mass flow rate turned on.
However,after 100k iterations, I still cannot get expected mass flow rate through the two outlets.
Could anybody give me some suggestions about this?
foolboy007 is offline   Reply With Quote
Old   April 4, 2012, 03:24
Zigainer is on a distinguished road
I also had problems with pressure outlet and traget mass flow rate (see http://www.cfd-online.com/Forums/flu...flow-rate.html)
and here is how fluent does it:
https://www.sharcnet.ca/Software/Flu...ug/node244.htm
In your case I would just use pressure outlet without traget mass flow rate and adjust the gauge pressure until you get your mass flow rate
Zigainer is offline   Reply With Quote
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 12:19
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 14:41
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
