how to trigger combustion instability in fluent |
February 26, 2012, 02:49 |
Zhong Zhiyuan
Now I am doing combustion in a rijke tube and I follow the work of C.-C. HANTSCHK AND D. VORTMEYER (NUMERICAL SIMULATION OF SELF-EXCITED THERMOACOUSTIC INSTABILITIES IN A RIJKE TUBE, 1999). In their work, they mentioned that a pressure disturbance needs to be imposed to find the combustion instability ( the limit cylce). However, I cannot find the limit cycle even if I added this initial disturbance. I wonder if anyone knows how to trigger the combustion instability in a rijke tube and could give me some suggestions to find the limit cycle. Thanks for many suggestions best regards, Zhong Zhiyuan |
April 4, 2012, 12:49 |
how to trigger combustion instability in fluent Reply to Thread
raj
Hi zhongzhiyuan,
I am also following the same work as you mentioned. I am also not getting the limit cycle. I am doing a complete transient simulation starting with P(inlet)=0.5 pa and P(outlet)=0 pa and reach upto a steady state. Then I apply the initial disturbance by changing P(inlet)=30 pa and running it for a small time. Then I change the P(inlet) to 0.5 pa. But I am not getting any oscillations. Kindly tell me what is your approach? Thanks. |
April 4, 2012, 22:34 |
Zhong Zhiyuan
Hi rajk:
I am still working on that. Since I have a different gemotry, I do not know if I can find the limit-cycle or not. If you simulate the same geometry (straight rijke tube), I think you should follow their settings and simulation procedure. Besides, according to other paper, the second order method for both spacial and time discretization should be used and the time step size should be small enough (less than 5e-5) with enough time step (let's say 2e5, 10s, or longer) because sometimes the onset of the osccillation takes some time. Besides, I have repeated their work ( the 3 mm long rijke tube) by adding a sine pressure flucuation at the outlet. With it, I can find the limit-cycle easily with a time step size 1e-4 ( see the pic). Now I am doing different geometry and I am trying to find the self-excited osccillation ( without artificial perturbation). I will give it a long time to run to see what happen. I hope this can help you and tell me if you have any finding. Best regards, Zhong Zhi Yuan |
April 4, 2012, 22:38 |
Zhong Zhiyuan
besides, PISO velocity-pressure coupling should be used
April 5, 2012, 10:32 |
raj
Hello Zhong Zhi Yuan,
Your above reply was really helpful. Thanks for that. I have a query on your horizontal rijke tube with artificial perturbation. However, I am not getting the pressure fluctuations as seen in your image even with giving sinusoidal pressure fluctuation(p=30 pa) at outlet. Even the residuals dont converge after some time. I really dont understand when the vortmeyer paper says "If a small pressure disturbance (p=30 Pa) is imposed on the obtained steady state solution the system becomes unstable and self-excited thermoacoustic oscillations evolve". Could you please tell me what are your magnitude for the pressure fluctuation(perturbation) at outlet and its time period. For how long you give this perturbation? I hope you have written a udf for this. As for the self excited oscillations, I am also working on one of them but that includes gravity(vertical rijke tube). Thanks. Raj |
April 5, 2012, 23:09 |
Zhong Zhiyuan
Hi Raj:
For the articial perturbation, I think you should first compute the steady state and use it as the initial condition for unsteady, this will make the onset of osicillation faster. If you start with transient computation directly, it may take longer time and I have no experience about that. For the convergence, when you start the transient, sometimes it cannot converge within the set up iterations for each time step(20 iterations by default). However, I do not think its a problem because the residuals are almost satisfied the criteria. The magnitude of the perturbation I also use 30 pa at the outlet. The geometry I set is axissymmetry. I only apply the perturbation to 3 m long tube and I don't try the 1 m tube. I think you are right with the initial perturbation mentioned in the paper and it is just the 30 pa at the outlet for some time and 0 pa after that. Best regards, Zhong Zhi Yuan |
April 7, 2012, 05:29 |
raj
I am doing the horizontal rijke tube simulation of 3m. But the pressure oscillations seems to be decreasing in amplitude(see image attached). I haven't ran the simulation for long enough but I doubt that the pressure fluctuations will die out. Was this kind of thing happening in your simulation? Thanks Raj |
April 8, 2012, 03:04 |
Zhong Zhiyuan
Hi Raj:
I think you dont add a continuous sinusoidal pressure wave at outlet. Otherwise, you will have a continuous perturbation. You should use the UDF to add a gauge pressure like 30sin(2*pi*f*t) at the outlet and by this way I am sure you can have the limit-cycle except it is not the self-excited one. And I have already successfully find the self-excited oscillation even in a different geometry by using the method I mentioned to you. Since I am working on a paper, it is not convenient for me to show you the results. But as I mentioned, the time step size and the running time is important. I use high performance computer (32 processors) to run 30 hours to see the onset of oscillations and another 10 other to saturated to the limit. Initially the perturbation added to the outlet (self-excited) does decrease and after long time starts onset. So use more processors and parallel computing for your simulation and give some patience. I have been working on it for 5 month to get the expected results. good luck Zhong |
November 28, 2012, 23:24 |
Help with the UDF
DDj
Dear Users,
I am very new to Fluent, I know how to add a UDF but have no experience on how to write one in C. Could you please post your codes for the UDF to give sinusoidal pressure at the outlet. And also how long should I wait before I change the outlet pressure back to 0 . I am doing a steady calculation first and after completion switched to transient and do I start with with outlet pressure as the one in UDF ? And after how long I switch back to outlet pressure of 0. And I will be very very thankful if one of you could post the UDF code. Please help me out. |
December 1, 2012, 22:27 |
Zhong Zhiyuan
hi xebid:
here is an example for you: /************************************************** ********************/ /* unsteady.c */ /* UDF for specifying a transient velocity profile boundary condition */ /************************************************** ********************/ #include "udf.h" DEFINE_PROFILE(unsteady_velocity, thread, position) { face_t f; begin_f_loop(f, thread) { real t = RP_Get_Real("flow-time"); F_PROFILE(f, thread, position) = 0.36 + 0.01*sin(477.*t); } end_f_loop(f, thread) } in fact, there are many example and tutorial online for you to learn how to use udf. you just need to write in text file and save it as c file. to change the outlet pressure, you only need to do it in fluent( change outlet gauge pressure to 0 after you running for a while.) if you want to learn more, we can have a look at my short paper about the fluent simulation following this link:http://www.ijetch.org/abstract/393-E0046.htm. regards, Zhong |
December 1, 2012, 23:18 |
#11 |
DDj
Hi Zhong ,
Thank you for the code but I have the same geometry and ran steady first and then transient and then used all second order and PISO scheme . I did put step size to 1e-5 and upto 2e5 steps ran with sinusoidal Pout till like 8000 steps and swtiched to zero and I donot get instability. BUt my nesh is coarse can you give me tips please I have been running to a long long time but no onset of stability. |
December 2, 2012, 22:06 |
Udf
#12 |
zhangmin
Hello,everyone!I want to ask a question:how to compile a udf about Convection heat exchange between gas and solid ,Radiation heat exchange between wall and solid.I use fluent software to simulate a two-dimesion rotary kiln.I want to ask for help.Thank you for your reply.
December 4, 2012, 01:12 |
#13 |
Zhong Zhiyuan
Hi Kaixin,
I do not have experience in using udf for this. However, we can set the coupled wall for heat exchange between fluid and gas in fluent. Radian can also be set in fluent boundary condition. this is much a easy way. Otherwise, if you use udf, you have to write the code correctly to loop our boundary elements for these purposes. |
December 4, 2012, 01:18 |
#14 |
Zhong Zhiyuan
Hi Xebid,
in my short paper, I have already given how I trigger the instability. if it is still not clear to you, you can find the reference paper to read in my paper. basically the idea is to introduce an initial disturbance (either velocity or pressure will do), and then let the fluent runs for the self-excited stability. of course, it should run for a while. just for your information, I will High Performance Computer to run this. meanwhile, we can check your boundary condition set and scheme you use. |
February 25, 2017, 12:53 |
Combustion instability in Rijke Tube
#15 |
Atul Patil
Rep Power: 9 |
I am trying to capture pressure fluctuations occurring in Rijke tube, referring the work done by c.c. hantschk and d. vortmeyer. Initially I started with steady state but facing a error. Divergence detected in AMG solver : Temperature I reduced URF's, Changes v cycle to W cycle too but it won't works. What should I do to get converge solution for that case, Please help me...! Thanks in advance...! Regards, Atul Patil. |
February 25, 2017, 17:07 |
#16 | |
Lucky
Rep Power: 66 |
It's a transient acoustic problem so you want to take small time steps and keep all your URF's default. Use COUPLED solver or PISO. I recommend PISO as a first start. You can do W cycle or F cycle if you want, but they don't make much difference at small time-steps. |
February 27, 2017, 00:06 |
#17 |
Atul Patil
Rep Power: 9 |
Lucky sir, thanks for your fruitful reply..!
I want to get steady results first and then proceed for transient simulation. so I chosen following parameters but still facing an error Divergence detected in AMG solver : temperature Solver - Pressure based, PISO Boundary Conditions Inlet - 0.36 m/s and 0.5 Pa guage pressure. Outlet - Pressure Outlet (Atm. condition) . Heater Band - Wall (no slip, 3000 K. temperature) . Please suggest me that how to fix this problem and get converge solution. |
February 27, 2017, 00:49 |
#18 | |
Lucky
Rep Power: 66 |
For steady, PISO should also be okay. You can switch to SIMPLE but it shouldn't change much because the Rijke tube is very simple. When you get divergence errors always check your boundary conditions, check your initial conditions, and check your mesh. Try an adiabatic/isothermal simulation and see if temperature still blows up. Turn off the heater in the Rijke tube and make it adiabatic. Make all walls adiabatic and just have an inlet with some temperature and outlet. It's now a basic flow in a pipe problem which should work, unless there's another mistake somewhere else. |
February 28, 2017, 06:08 |
#19 |
Atul Patil
Rep Power: 9 |
Thanks Lucky Sir..!
Your suggestions helps me a lot. As you suggested, I checked meshing and made it successful. Now I am doing stedy simulation and getting results without an error, only problem is solution doesn't get converge till 35000 iterations. Should I proceed further or reduce URF's ? Simultaneously I started transient simulation using PISO scheme with 0.00005 time steps and It is still going on... Would you please guide me to plot Pressure Vs time graph. Thanking You..!!! |
March 4, 2017, 05:44 |
Dera
#20 |
mrwan
Rep Power: 10 |
DEAR zhongzhiyuan
YOUR SHORT PAPER(http://www.ijetch.org/abstract/393-E0046.htm.) NOT OPEN PLEASE RELOAD IT AND I D LIKE TO KNOW UR MAIL THANKS ALOT |
combustion instability, limit cycle, triggering method |
Fluent PDF Combustion viscosity problem | laxwendrofzx9r | FLUENT | 0 | December 6, 2011 09:21 |
coal combustion in FLUENT.. | ramakant | FLUENT | 0 | May 1, 2011 00:15 |
Combustion SImulation in Fluent | santhosh1987 | FLUENT | 0 | May 14, 2010 10:32 |
combustion in fluent..help | ssj | FLUENT | 1 | June 11, 2007 12:54 |
instability in fluent | marangoni | FLUENT | 2 | March 4, 2004 23:30 |
