Symulate hysteresis stall effect on an Airfoil
Old   March 6, 2012, 05:34
Default Symulate hysteresis stall effect on an Airfoil
Nicola
sirnick is on a distinguished road
Hi everyone!
My name is Nicola and i'm a doing some analysis in fluent for my thesis in Engeneering. I'm doing an analysis on effect of the stall hysteresis on an NACA0018 airfoil.
Some one can help me about how set the analysis?
I need to create a variation of the velocity direction in the velocity inlet surface.
sirnick is offline   Reply With Quote
Old   March 6, 2012, 06:08
Far
Sijal
Why? are you looking for post stall simulation?
Old   March 6, 2012, 06:17
Nicola
Yes, i'm looking to simulate the post stall condition in particular the hysteresis phenomenon. If i want to simulate this, i need to decrease the angle of attach in the moment of deep stall and after increase it.... this to reproduce the hysteric phenomenon (see the attack file)
Old   March 6, 2012, 06:35
Far
Sijal
I need to decrease the angle of attack in the moment of deep stall and after increase it..
This should be done by computational model and not by you.
Old   March 6, 2012, 06:38
Nicola
Yes, i agree your idea..... but HOW can i set the computational model to do this?
Old   March 6, 2012, 06:44
Far
Sijal
one idea which one of my student and my self implemented is to run the transient simulation at stall angle and it will give you required results. First it will go into stall and then it will try to recover. During recovering you get high angle of attack and high lift. After when it goes into stall, you get low lift and this loop repeats indefinitely.
Old   March 6, 2012, 06:55
Nicola
Ok, i will try this afternoon!
I defined my model like in this tutorial:
https://confluence.cornell.edu/displ...oil+-+Geometry
So now i defined the angle of attack, like the different direction of wind in the velocity inlet surface. If i follow your method, i set the stall angle of attack (13° @ Re1,5e5) for the velocity inlet and i calculate a transient simulation. How much time must last the transient simulation?
Thank you very much for your help!
Stall capture on 3 element airfoil: what turb model? Verfblikje OpenFOAM Running, Solving & CFD 14 February 22, 2017 15:30
Determining Stall Angle of 2D Airfoil Active.Aero.Fiero FLUENT 3 October 27, 2010 09:07
Airfoil in Stall - Turbulent model. Jack FLUENT 0 November 7, 2008 02:53
Airfoil at stall angle cfd_newbie FLUENT 10 February 5, 2008 11:33
Airfoil in stall Park Geun Hong FLUENT 4 February 24, 2000 21:00
