Solving the Volume Fraction Equation in a Multiphase M.
Like Tree1Likes
  • 1 Post By Max585
Old   August 2, 2011, 14:18
Exclamation Solving the Volume Fraction Equation in a Multiphase M.
Massimiliano
Max585 is on a distinguished road
Hi there,
I need to solve two simple scalar transport equations (two scalars UDS0, UDS1 introduced, no diffusion, no source), along the Fluent continuity, momentum and Volume Fraction Equations, for a Eulerian Multiphase Model.
At this initial stage, the two scalar transport equations have been defined to easily replace the Volume Fraction Equation of Fluent. In other words, we want them to give us the same evolution for the scalars UDS0 and UDS1 in time and space, as the Fluent volume fractions equation does for the C_VOF. The problem turns out to be more difficult than it seems though!
Initially, I tried to disable the volume fraction equation from the Controls panel, since the scalar equations were supposed to give us the same results. The simulation slows terribly down, and diverges after a while.
Then, I decided to leave all the equations enabled, overwriting in the UDF the C_VOF with the scalars. The evolution seems to be well predicted, but the simulation crashed down inexplicably after 500-600 timesteps.
The last attempt, I left all the equations to go, without the overwriting, but even if their dynamic are very similar, the scalars tend to wrong values, since their sum is sensibly bigger than one!!!!!
How can I overcome this problem??Please help me!!!!!
Thank you
Max
somy1 likes this.
Max585 is offline   Reply With Quote
Old   March 20, 2012, 07:49
chenxizhong
chenxizh is on a distinguished road
Hi Massimiliano, have you solved the promble? rencently I encounted the same problems, can you give me some suggestion? thanks.
Originally Posted by Max585 View Post
Hi there,
Thank you
Max
chenxizh is offline   Reply With Quote
fraction, multiphase model, scalar, uds, volume
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
Error log vw.cfd OpenFOAM 6 August 7, 2009 05:44
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
