Airfoil 2D help
Like Tree1Likes
Old   March 20, 2012, 15:30
Default Airfoil 2D help
Pranav
pranavom8 is on a distinguished road
Hello ppl,
I'm trying to do a 2D airfoil analysis using ansys fluent, I used the 3 part tutorial video to mesh a CH type mesh in ICEM CFD, when I import into fluent the mesh imports fine, I did scaling to 0.254 to x and y to convert the size to inches(my chord length is 10"), after that when checked for mesh it shows errors as show in the attached picture. When neglected and continued using steps from
https://confluence.cornell.edu/displ...irfoil-+Step+4
while running the solver it converges till 20 iterations and after that it starts throwing fatal error Reversed flow.
I dunno where I'm going wrong please help, my angle of attack tested is 8degrees
What am I doing wrong?
Is there anything wrong with the mesh,
pranavom8 is offline   Reply With Quote
Old   March 22, 2012, 09:11
Zigainer is on a distinguished road
You could lower the under-relaxation factors. And I always start my problems with less mass flow (lets say 1/3) and then increase mass flow slowly.
What are your boundary condition? Pressure inlet? Pressure outlet? Operating pressure?
Zigainer is offline   Reply With Quote
Old   March 23, 2012, 05:43
Default Thanks on your reply
Pranav
I have defined the walls are pressure fields and in the fluent I defined them as velocity inlet and pressure outlet, with a velocity of 20ms^-1, and the pressure outlet set to guage, 0Pa. I tried reducing the under relaxation factors from 0.3 to 0.2 and 0.1 but that didnt help. The chord length of my model is 1m in the ICEM CFD(leading edge 0,0,0 and trailing edge 1,0,0) I used the scaling in fluent to scale down to 10" by using 0.254 in the places of x and y in the scale.
Thanks in advance for any help
Old   March 23, 2012, 09:24
robboflea is on a distinguished road
Try to initialize your solution with FMG initialization: you find it from command line menu in Fluent under 'solve/initialize/FMG initialization'. This generally solved all my problems concerning backflow. Let me know if it doesn't work.
Cheers
Rob
robboflea is offline   Reply With Quote
Old   March 23, 2012, 09:54
Smile
Pranav
Cheers
Rob
Sure Rob thank you!!!
Old   March 25, 2012, 03:07
Smile helpful
Pranav
I still haven't solved, but for anyone who has this same problem, you could use this information in the site
https://www.sharcnet.ca/Software/Flu.../tg/node53.htm
Old   March 25, 2012, 04:02
Lucky
Originally Posted by pranavom8 View Post
Hello ppl,
I am not familiar with ICEM but,
Fluent imports cell coordinates in the default units of meters [m]. 1 inch contains 25.4 mm or 0.0254 m. If you did a scaling of 0.254, then your scaling is off by a factor of 10.
Check the actual physical span of your mesh. Go to the scaling window, and check if the min and max x and y coordinates correspond to the actual extent of the domain.
Old   March 25, 2012, 05:25
Sometimes I had problems when using 0 Pa as a reference condition. Try to see if you get something when using a non-zero operating condition.
Could ypu please specify what are your boundary conditons on the top and bottom walls of the domain?
Cheers,
Rob
Old   March 28, 2012, 21:37
Tan
Tom Lucius is on a distinguished road
Hi, i am running 2D flow over NACA 0012 simulation based on this tutorial https://confluence.cornell.edu/displ...il+-+All+Pages.
The default chord length i get is 1 m.
Means if i am analyze based on Reynolds number = 360,000
Re= (Density X Chord length X Velocity)/(dynamic viscosity)
Density = 1.225
Chord Length = 1m
Re= 360,000
Viscosity = 1.7894 x 10 ^-5
The velocity i get is 5.2586 m/s .
With this velocity input, i cant get the accurate drag coefficient.
Anyone help me to remove my doubts?
Tom Lucius is offline   Reply With Quote
Old   March 28, 2012, 21:47
Lucky
Density = 1.225
Chord Length = 1m
Re= 360,000
Are the drag coefficients calculated by Fluent? If so, did you remember to specify the reference values?
Old   March 28, 2012, 22:35
Tan
Re = 360,000
Angle of attack = 4 degree
Type of Solver = Density Based
Viscous = Inviscid
Boundary Conditions:
Inlet = Velocity inlet
Outlet = Pressure outlet
X velocity = 5.2586 cos 4 = 5.2458
Y velocity = 5.2586 sin 4 = 0.3668
Reference Value:
Compute from inlet
Residual continuity = 1e-6
Solution Steering:
Flow type = Incompressible
My result:
Lift = 0.411
Drag = 0.00377
Published paper result:
Lift = 0.44
Drag = 0.0098
Old   March 28, 2012, 22:40
Lucky
Reference Value:
Compute from inlet
That didn't really help...
Where is this magic lift and drag coefficient coming from? Is that the Fluent output or did you calculate it? It seems like you are just taking whatever Fluent is spitting at you, is this the case?
Have the solver report the raw Forces on the surfaces and calculate (by hand + calculator) independently and see if you can the same lift and drag coefficients as the solver, even if they do not match published literature. This way you are at least sure the coefficients are being calculated properly (that is Lift = 0.411 and Drag = 0.00377).
And what are your reference values? You need to define all the correct reference values to get the right coefficients.
You need to have the reference area, density, and velocity specified consistent with your problem. I do not think the reference length matters (they are not used in the calculation of the lift & drag coefficient), but you can set that to be your chord length too if it helps.
Old   March 28, 2012, 23:07
Tan
You are not really helping...
I thought the lift and drag coefficient is obtained from Fluent. Maybe I am misunderstood the tutorial.
As you mention, after I getting Fluent result (lift & drag coefficient), I must calculate by myself to compare with the Fluent result?
Old   March 28, 2012, 23:19
Lucky
As I mentioned, you need to specify the correct reference values in order to get any meaningful results from lift and drag coefficients. At the minimum, for your problem, reference area, density, and velocity should be specified consistent with your definition of lift and drag coefficient. Use the same definition as your "published paper" so that you can directly compare the two.
I doubt your reference area is 1 so it appears to be the first thing that is wrong. For reference area, I am not sure which area is being used in your "published paper" definition. There are many ways to define these coefficients, some based on planform area and some based on projected frontal area. You will have to look it up and then specify the correct reference area.
Make sure that the reference density and velocity are correct! Don't be lazy. Also do not assume that the reference density and velocity are the same as the material property or boundary condition. Double, triple check them!
You can always double check by calculating it by hand as I mentioned earlier to make sure everything is making sense.
Tom Lucius likes this.
Old   March 29, 2012, 02:17
Viscous = Inviscid
Sorry but I'm missing something. Are you trying to calculate the drag by using a Euler solver? Does Fluent use a kind of magic to do that?
Rob
Old   March 29, 2012, 04:34
Tan
The chord length which I used in Fluent is by default (1m).
The published paper's chord length is 15.24 cm and span is 0.91 m.
I not good in using Fluent, so I do not know how to make the chord length from 1 m to 15.24 cm, and also the span.
Is there any idea or advice for me?
My NACA 0012 shape is formed by the list of coordinates which provided by the tutorial.
Old   March 29, 2012, 05:08
Assuming that your geometry is correct you don't need to change it! you only need to change the reference values in Fluent. Those values are used by Fluent to calculate meaningful non-dimensional parameters like Re or Lift and Drag coefficients.
For info on houw to change them please refer to Fluent manual.
Cheers,
Rob
Old   March 29, 2012, 12:34
Lucky
Sorry, what I meant was that you should use the same "type" or reference area/length as the published paper. However, define the reference values according to your model.
i.e. if they use the chord length as the reference length, then you also use the chord length. if they use planform area, then you also use planform area, etc. But when it comes to the actual values, use your chord length (not the paper's chord length).
You don't need to change your chord length, you just need to make sure that the right reference values are defined so that Fluent calculates your coefficients properly. Hope that helps.
Old   April 10, 2012, 02:59
Exclamation Mesh file
  #19
Pranav
Hello people I have included the mesh file in the zip file attached, I still get the flow reversal problem And I have no clue about the reference are and lengths modification. The boundary conditions can be verified from the file attached within.
Hope anyone could help.
Old   April 10, 2012, 05:19
http://hpce.iitm.ac.in/website/Manua...g/node1208.htm
from the 2nd result from google's when searching for "fluent reference values". What's not clear in that? Use the reference values of your profile but using the same definition of drag and lift coefficients used in the reference paper.
For what concerns your mesh for me it has some quality problems starting from the too big density step on the leading edge, the high aspect ratio of the cells far from the airfoil, the cells to big on the outlet boundary.
By the way this couldn't be the only problem to your simulation. What are your boundary conditions? What solver are you using? I read a few posts above that you were using a Euler solver? Was that a mistake or is that true?
Low Speed Airfoil Mancusi FLUENT 7 April 3, 2014 06:11
[GAMBIT] Meshing airfoil using .dat file problem creggie ANSYS Meshing & Geometry 10 June 27, 2010 19:24
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 08:11
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 11:31
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
