reversed flow during RNG in turbulence-k epsilon
Old   September 6, 2007, 20:57
Default reversed flow during RNG in turbulence-k epsilon
Suman Kandula
friends,
I am doing CFD-analysis using FLUENT and GAMBIT combination to solve TURBULENT FLOW THROUGH ORIFICE. While preferring RNG-K-epsilon model, I am getting reversed flow in various iterations.
I request anyone to help me out in getting rid of this situation.
bye suman
Old   September 6, 2007, 21:58
Default Re: reversed flow during RNG in turbulence-k epsil
Sham
In my experience, if you get all the set up correct, the reverse flow will go away after some iterations. If not, make sure you initialise the turbulent correctly, and if your domain ahs an outflow, you may want to increase the distanace of the outflow BC. Changing to pressure outlet may help too.
Hope this helps.
Sham.
Old   September 10, 2007, 10:50
Y.harnane
hello, i'm working with Fluent CFD and for your case you should changing the outflow BC to pressure outlet as mensioned in Fluent Help.
good luck
Old   September 11, 2007, 08:37
Neil
Apart from increasing the extent of the domain you can initialise the solution using lower values. Decrease the inlet velocity,total pressure or mass flow rate depending on what inlet BC your using then increase it throughout the simulation. This will minimise the amount of reversed flow reported by the TUI. Of course you can wait like Sham said till reversed flow stops but depending on your BC values this may take a while.
Old   April 2, 2012, 07:12
Smile help me please!
mustapha
diomus is on a distinguished road
friends,
I am doing CFD-analysis using FLUENT and GAMBIT combination to solve ''supersonic air ejecteor''i choose pressure inlet1 and pressure inlet 2 and pressure outlet, I want to know if the reversed flow can influence the results,if yes i must to do what to avoid this message!
i'm waiting your answers please...
diomus is offline   Reply With Quote
Advice on turbulence model for complex internal flow JPBodner Main CFD Forum 1 September 3, 2011 03:07
Reversed flow error with thin film heater MK FLUENT 1 February 12, 2009 10:26
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
reversed flow Sastry FLUENT 5 March 22, 2007 08:05
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 04:04
