April 2, 2012, 04:44 |
Extrapolated values from input coordinates
Pierre LAURET
I have a question and I didn't find an answer in the fluent documentation. Is that possible to export values at specified coordinates (not necessarily on a grid node) in Fluent? Thanks for your replies. Peter |
April 2, 2012, 12:19 |
banty
I think no.
April 2, 2012, 21:10 |
#3 | |
Lucky
Rep Power: 66 |
I have exported data at individual points before by simply creating point surface monitors and just choosing any of the vertex schemes (minimum, average, maximum). If your surface is a single point, the three will be the same (since there is only 1 vertex). I have entered locations that do not correspond to the grid locations with no issues. However, I do not know what the mechanics are in Fluent for when the specified location is not exactly a grid node location. There may be some magic that Fluent uses to interpolate, or that it may pick the nearest vertex. I am not sure, but if all you care about is exporting data at a point, then I am sure it will work as I have done it many times. Again, I know for sure that I did not enter the exact cell locations. Who even knows what the exact locations are, all the way down to machine precision? You can perhaps fool Fluent into interpolating by using a surface integral. For example, a area-weighted average, surface integral of a point, will be similar to a linear interpolation of the values at surrounding vertices. Just an idea. I hope that answered your question, somewhat. |
April 3, 2012, 03:39 |
#4 | |
Pierre LAURET
I'm gonna try this solution and I let you know. Peter |
August 23, 2012, 05:10 |
coordinates doubt
kunar
Dear friends,
i am doing 3D wing analsysis by using gambit & fluent in gambit i selected the coordinates is +y view in gambit (ie x is towards right, y is towards horizontal wing & z is downwards,) see image 1 xyz coordinates, after i finished my meshing i import in fluent in that if i see grid in display option the coordinates its shows (x is towards right, y is vertical & z is horzontal) see image 2 xyz coordinates, how i can change my coordinates in fluent according my gambit coordinates, please find the attached images, In gambit my wing looks towards bottom ie actual geometry, but in fluent its change, see wing& xyz coordinates closely in both images,please help me |
coordinates, export |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
It would be wonderful if a tool for FoamToTecplot is available | luckyluke | OpenFOAM Post-Processing | 165 | November 27, 2012 06:54 |
max node values exceed max element values in contour plot | jason_t | FLUENT | 0 | August 19, 2009 11:32 |
exact face values | RubenG | Main CFD Forum | 0 | June 22, 2009 11:09 |
Plotting raw data values | Wilesco | Siemens | 0 | January 5, 2006 05:34 |
