2D model vertical plates with constant heat flux
Old   April 9, 2012, 16:51
Default 2D model vertical plates with constant heat flux
Smsc S
smsc59 is on a distinguished road
I'd like to ask for help on how to make a correct model of 2 thin vertical plates (0.15cm x 7cm x 60cm) in a large water pool (6m x 9m x 7m).
I am confused on how best to represent this in 2D. Should the plate in 2D be (0.15cm x 60cm) or (7cm x 60cm) ? The heat flux, q" (W/m^2) should be stronger on the larger surface but since I want to see the flow & temperature profiles between the plates, how should I choose?
I am using Gambit to mesh and Fluent for CFD simulation.
Thanks
smsc59 is offline   Reply With Quote
Old   April 9, 2012, 19:25
Igor
DaddySpeleo is on a distinguished road
Hi!
1. If you have 2D problem - so - you consider all derives in 3rd directions are equal to zero. So - you shoud decide it.
2. Your wrote about two plates. And what avout their position? Can you give a picture?
DaddySpeleo is offline   Reply With Quote
Old   April 9, 2012, 21:22
Default Re: 2D model vertical plates with constant heat flux
Smsc S
Let me re-phrase my question about the problem setup.
In Fluent, I chose the wall condition for the plates to be constant heat flux, q" . In this case, does the plate area (in 2D) refer to the thin-face or the broad-face of the plate?
Can either one be chosen but then adjust the 'Reference values' in Fluent under 'Area' and 'Depth' ?
What area does the q" refer to? Or in 3D what volume does the q''' refer to?
I've attached 2 pictures for this problem.
Appreciate any comments and help. Thanks
convection, fluent, gambit, vertical flat plate
Implement constant heat flux boundary condition new_at_this Main CFD Forum 2 April 6, 2012 23:35
constant heat flux BC sunny Main CFD Forum 3 January 21, 2005 10:03
constant Heat flux at the wall hatta FLUENT 2 January 9, 2004 07:13
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 05:09
BC for constant heat flux saidi Main CFD Forum 2 July 17, 1998 15:02
