Home > Forums > General Forums > Hardware
Suggestions for AMD powered mini Servers for HPC
Old   August 16, 2015, 13:59
Default Suggestions for AMD powered mini Servers for HPC
Manoj Kumar Gangadharan
manojkg.me is on a distinguished road
We do CFD simulation based on particle methods,(SPH, MLPG kind of). We use custom codes to develop and run the simulation and compare it with commercial solvers like ANSYS Fluent and CFX. We are a small research group and currently own 3 Dell T1700 workstations, all powered by Intel processors. (2*I7 8c and 1*Xenon 8c) with 32GB memory each.
We would like to upgrade performance of the simulation. We are looking at AMD powered mini servers.
Regarding simulations:
  1. For commercial solvers: Cells anywhere between 3 to 16 million.(ANSYS and CFX)
  2. For in house solvers: 3 to 12 million particles.(Have openmp capability).
Can somebody please suggest me a base configuration to start with?
manojkg.me is offline   Reply With Quote
Old   September 7, 2015, 09:14
Micael
Micael is on a distinguished road
First suggestion is to go for Intel, not AMD. I see you have i7 8-core, that should be 5960X. From that point, one can only ends up disappointed with AMD (for CFD utilisation I mean)
How many HPC licence do you have for ANSYS?
Micael is offline   Reply With Quote
Old   September 7, 2015, 09:42
Smile
Dear Micael,
Thank you for the reply. I work in a university. I'm not sure of the number of licences we have at out HPC facility.
I work in a lab and the HPC facility is common for all users, my professor want to get a high performance server to address the computational demands of our team. We are basically involved in developing custom programs for CFD simulations specific to the study of gravity waves using particle methods(like SPH). ANSYS is used to compare and benchmark these results.
This is a rapidly growing team of researchers and collaborators. So we are looking at long term upgradation option rather than short term benefits in cost.
I hope this answers the question. If the reply is confusing, please let me know.
Regards
Gangadharan, Manoj Kumar
Old   September 7, 2015, 09:53
Micael
Dear Gangadharan,
First thing would be to estimate how many core you need for the cluster. You can probably do that using your workstations.
As an example, if you figure out that you want the cluster to run large cases 10 times faster than the workstation, then you would aim in the 100-core range.
Old   September 7, 2015, 10:33
Smile
Dear Micael,
Thank you. We were actually looking at machines, that are called mini servers. My professor have been told by someone about this machine and I was asked to come up with a feasible solution. Speed is an important factor. I will discuss with research group and update you regarding the same. Since we code based on openMPI, I think more number of cores can do wonders.
Will you be able to provide me an estimate for a 100 core machine?
Regards
Old   September 9, 2015, 15:10
Micael
My opinion would be to consider a 8 node cluster using the processor Xeon E5-2643 v3. (2 x 6-core per node). Interconnect would be FDR InfiniBand (Mellanox SX6005 switch and MCX353A-FCBT adapter as example). 64 GB of ECC DDR4 2133MHZ per node (8 x 8GB module).
Such a system has 96 core and should be around 55 000 USD.
Old   September 10, 2015, 01:52
Smile
Dear Micael
Thank you. I will put forth your suggestion as one of the options. I don't really know how much the price is going to be in India. I will update you regarding the same. Mean while, I will start my base research with this model and combination. Thank you.
Regards
Manoj
