January 23, 2022, 21:01 |
Weird Fan Behavior For H12DSi-N6 Motherboard
Daniel Dotson
Rep Power: 5 |
Thanks to the help of this forum, I was able to successfully build and setup a dual EPYC workstation! I am getting some weird fan behavior that I want to make sure I understand before running anything particularly demanding. After booting, the fan RPM seems to smoothly ramp up and down in a cycle with a period of about 10 seconds. The H12DSi-N6 does not seem to have fan options in the BIOS. I have the CPU2 cooler plugged into FAN2, CPU1 cooler plugged into FAN6, and the Enthoo Pro case fan controller plugged into FANB. I am not certain if all fans are oscillating or just the case fans. How can I get the fans to operate at a more consistent RPM? What is the best way for me to monitor sensors and modify fan settings while running this system with Fedora? I apologize if these are naive questions. |
January 24, 2022, 02:44 |
Alex
Rep Power: 46 |
It's a very common issue with Supermicro boards. The solution is to lower the fan thresholds via IPMI
https://calvin.me/quick-how-to-decre...-fan-threshold or https://www.informaticar.net/supermi...ard-loud-fans/ |
January 24, 2022, 12:19 |
#3 | |
Daniel Dotson
Rep Power: 5 |
I tried that first link and got some weird results. According to the ipmi web interface, the thresholds are now lower, but not what I set them to, and the RPM is now stuck on 1400. It also says one of the fans is critical for some reason, even though it’s spinning and clearly within thresholds. I will try again after I get off work in a few hours. Let me know if you have any ideas about what could be going wrong. |
January 24, 2022, 12:43 |
Alex
Rep Power: 46 |
I'm fairly certain this is what's going on here. I had the same issue with my Supermicro H11DSI and solved it with that. And there are plenty of people on the internet with the same problem.
What happens is this: the SM software detects a fan spinning lower than the critical limit. As a result, all fans are set to 100% for a while to unstuck them and prevent damage. Fan speed then returns to normal, and the check is repeated every 10s. Which leads to the cycling behavior when slow-spinning fans are connected. Maybe you just had a typo in your commands. Here are some commands to read the current settings, that should help you figure out what went wrong: https://blog.pcfe.net/hugo/posts/201...pyc-ipmi-fans/ |
January 24, 2022, 21:04 |
Daniel Dotson
Rep Power: 5 |
Ok I did more testing. I set the lower thresholds to 0 100 200. IPMI then says Low NR and Low CT are 0 and 140 respectively. It doesn't seem to let me raise or lower these thresholds after this. I get a confirmation that it changes in terminal but then when I run ipmitool sensor it still shows 0 and 140. This persists after a reboot as well.
I reset my BMC, which made the fans start surging up and down again for the reasons mentioned. I then set the thresholds again. Low NR and Low CT are stuck at 0 and 140, but the RPMs are both reasonable this time and I do not have any "critical" fans anymore. So my fans seem to be working properly now, but I can't change the threshold anymore and I am not sure why. FanThresh.png |
January 25, 2022, 02:24 |
Alex
Rep Power: 46 |
No idea about that, sorry. I just set these limits once, and left it there when it did what I wanted.
Maybe setting one of them to 0 is a problem. or maybe SM changed the interface slightly this time around |
January 25, 2022, 10:39 |
#7 | |
Daniel Dotson
Rep Power: 5 |
I might try other IPMI tools eventually out of curiosity, but I don’t think I really have any need to change it again. Thanks for all the help! I really appreciate it. Without your advice on this forum, I would have never been able to put together such a fantastic system. |
control, cooling, fans, oscillate, supermicro |
Appling a fan inside the domain/duct | Tobi | OpenFOAM Running, Solving & CFD | 3 | April 12, 2022 05:57 |
How to build current blower fan model in Flotherm | eric0722 | FloEFD, FloWorks & FloTHERM | 3 | January 2, 2021 02:36 |
Trouble modelling a jet fan | josee | OpenFOAM Pre-Processing | 0 | September 23, 2016 13:06 |
Constant Power Fan Model using General Momentum Source | Dano62 | CFX | 0 | April 14, 2016 13:09 |
fan driven flow, Fan BC validation (getting lost) | soonic | OpenFOAM Running, Solving & CFD | 0 | July 7, 2013 19:16 |
