Fluid-solid flow in pipe model...need help..
Old   May 11, 2012, 13:07
Default Fluid-solid flow in pipe model...need help..
Oat Mongkhol
Fishburn is on a distinguished road
I have a aproblem to set up the proper model for Fluid-solid Flow in pipe.
I want to simulate the fluid transport ability (density of fluid is less than solid partical), which i will vary flow rate and density to see the proper condition the clean up the solid partical in the pipe....
Please give me the guide line....Thanks in advance
Fishburn is offline   Reply With Quote
Old   May 11, 2012, 13:13
Oat Mongkhol
My model will use volume fraction inlet as Fluid/solid = 80/20...
as the outlet side, when the velocity of the fluid is not sufficient, some of the solid partical should stay in the bottum of the pipe as stationary layer while some of the solid partical will dispered in the fluid phase.....any ideas....to help Thanks
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
gas solid pipe flow tahar Phoenics 6 November 3, 2003 12:03
Turbulence model for Transient Pipe Flow Modeling Brian FLUENT 0 June 7, 2002 12:15
Turbulent non-Newtonian fluid flow using k-w model Athar Zaidi CFX 1 February 1, 2000 15:46
