Solidworks FLow Simulation - iterations??
Like Tree2Likes
  • 2 Post By evcelica
Old   May 15, 2012, 22:50
Question Solidworks FLow Simulation - iterations??
shahrul
alpharays is on a distinguished road
Send a message via Yahoo to alpharays Send a message via Skype™ to alpharays
Hi All,
I'm using solidworks to do convection heat transfer in the microcomputer. The problem is my understanding on the number of iterations.
2 simulations are done through 2 different setting on the iteration:
1) goals convergence (result obtained as in Pic 1 attached - stop at iteration 56)
2) maximum iterations = 42 (result obtained as in Pic 2 attached - stop at iteration 42)
How do I explain about the differences of data ( in this case temperature) at iteration 20 and iteration 30??
For goals convergence; what is mean by goal convergence?? is it equilibrium state/ condition??
This number of iterations are not explained about time, am I right?
** for pics, please go to this post: https://forum.solidworks.com/thread/55629
Thanks
alpharays is offline   Reply With Quote
Old   May 15, 2012, 22:58
Exclamation
shahrul
anyone who want to contact me.. please do so through skype..
my skype id is alpharays786..
thanks
Old   May 16, 2012, 10:28
Erik
evcelica is on a distinguished road
It was still iterating your solution, at iteration 20 and 30 you do not have true solution yet. The simulation will stop whether when you have reached you convergence criteria (residual values) or when you reach the number of max iterations.
This is why I hate SolidWorks, its so easy to use that people who obviously know NOTHING at all about numerical methods can run CFD problems and make pretty pictures.
sail and cdegroot like this.
evcelica is offline   Reply With Quote
Old   May 17, 2012, 00:25
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
Absolutely! In my experience it is a pretty weak CFD tool to start with, made worse by the fact that it is so easy for the inexperienced user to input garbage and obtain a "solution".
cdegroot is offline   Reply With Quote
Old   May 22, 2012, 09:39
Eugeny
chlp is on a distinguished road
It's steady-state solutions with not-physical time steps (default). It is desirable to know in advance the approximate solution. Otherwise need to use time-depended solution.
chlp is offline   Reply With Quote
flow simulation, heat transfer, iterations, simulation, solidworks
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
