Compressible Flow problem
Old   June 2, 2012, 18:36
Post Compressible Flow problem
Rahul Verma
verma_rahul is on a distinguished road
Hello Everyone,
I am solving compressible problems with pressure correction approach. I have derived pressure correction equation for unsteady compressible case and solved 2-Dimensional shock tube problem with implicit scheme. Full Navier equation is used as governing equation.
This is my first case and it is working for pressure ratio 5 to 15. with both staggered and collocated approach. This case is perfectly working with variation of grid size, relaxation parameter. So this case is perfectly working for me.
Now problem comes,
I am trying to solve this for plane channel flow case(2D fanoo flow).
Here is detail
Boundary condition:
For velocity : Inlet velocity is defined
No slip boundary condition is used for upper and lower wall
For exit boundary i am taking derivative equal to zero. dU/dx=0
dV/dx=0
For Temp : Inlet Temp is fixed
for walls dT/dy=0
for exit dT/dx=0
For Pressure:
Since we are not using any pressure boundary condition in SIMPLE, i am also not using in my case,
But in compressible case i need boundary pressures and density.
So for this i am using
dP/dy=0 for walls
and dP/dx=0 for inlet and outlet
for density: No boundary condition is required, calculating by gas law p/RT
This is my problem and this is not working.
Same formulation is perfectly working for shock tube case but not giving correct results for channel case
I think there might some issues with boundary because in both cases boundary has changed.
Please let me know what should i do for this
Thanks & Regards,
Rahul Verma
IIT Bombay
verma_rahul is offline   Reply With Quote
boundary conditions, compressible flow, simple algorithm
Boundary condition for compressible flow ( cavity lid problem) pike@91 Main CFD Forum 2 June 2, 2012 17:04
how to set BC for compressible flow target mass flow rate foolboy007 FLUENT 1 April 4, 2012 03:24
Negative density problem. compressible flow Karl Siemens 2 July 10, 2008 16:41
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
Problem on boundry of two phase flow youngan CFX 0 June 30, 2003 02:32
