structured meshing
Old   December 1, 2005, 07:16
Default structured meshing
Rashmi
hi
can anyone tell me how to create structured meshing in symmetric 3D pipe in gambit.
Regards rashmi
Old   December 6, 2005, 19:12
Default Re: structured meshing
Gede
If your problem is a straight 3D pipe, usually I would divide the pipe surfaces into 6 regions first. 2 are the inlet and outlet; 4 are the pipe itself, so the inlet/outlet plane is divided on its quadrant. Then create volume from the 6 surfaces. Mesh the edges in even number. Mesh the 4 pipe divided faces using mapping scheme, mesh the volume using cooper scheme. The inlet/outlet face will be meshed automatically. I hope this would help.
[Gmsh] Structured meshing in Gmsh the_phew OpenFOAM Meshing & Mesh Conversion 19 August 24, 2022 03:19
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
ANSYS Meshing: Structured Mesh with Inflation Antanas ANSYS Meshing & Geometry 1 June 18, 2011 20:23
3D wing + wind tunnel hexa structured meshing icemaniac178 ANSYS Meshing & Geometry 9 October 28, 2010 09:37
structured meshing Mavinakere FLUENT 4 March 1, 2002 15:52
