BEAM & WARMING METHOD
Old   July 22, 1999, 03:17
Default BEAM & WARMING METHOD
Yogesh Talekar
Can anybody help me with this. I am solving 1-D equations of the form dU/dt + dF/dx = 0 using Beam-Warming method. After finding jacoboan which is 3X3 i get them in the form dU/dt + B * dU/dx = 0 form I have denoted the elements of matrix as
B11, B12, B13,
B21, B22, B23
B31, B32, B33
After using Finite difference the equation becomes tri-diagonal and can be solved using THOMSAS algorithm
But there are calculations like B1[i] * U1[i] So should i calculate such term like
(B11[i]*B12[i]* B13[i]) * U1[i]
Or some thing else is needed to be done here? Can Anybody help?
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
Difference Between the Oscillations of Lax Wendroff Method and that of Beam Warming rizwanherl OpenFOAM Programming & Development 0 June 8, 2010 16:08
Best front tracking method for surface evaporation Komkamol Main CFD Forum 0 July 17, 2009 10:23
Code for most powerfull FDV Method D.S.Nasan Main CFD Forum 6 September 4, 2008 02:08
Radiation Module using discrete beam method Vipul Jain Main CFD Forum 1 May 2, 2006 09:32
