December 18, 2005, 22:15 |
Large velocity near aifoil trailing edge
hello,
i've a fractional step FVM structured 2D NS solver. I'm now trying to solve the flow past a NACA0012 airfoil. I initially just calculate the top half since it's symmetrical. The flow field seems ok. however now, I tried to simulate the full airfoil and large v velocities appear around the trailing edge region, especially the cells near the center line and just right of the trailing edge. I've tried to scan for programming errors but I've yet to find any. I've also compared the sym and full answers but I can't find the error. Has anyone encounter similar problems before? thanks |
December 18, 2005, 23:22 |
Re: Large velocity near aifoil trailing edge
Sounds familiar....
Are you working on Dr. Lohner's project for the CFD class? |
December 19, 2005, 00:09 |
I assume you use C-type grid and special boundary treatment on the cuting edge sttarted from TE. Be sure if the BC is correctly implemented.
December 19, 2005, 00:35 |
tiger: no
versi: I've used special BC for the cutting edge. I've got a symmetrical ans, everything seems "ok" except for large velocites at cells near trailing edge.... |
ICEM aircraft mesh trailing edge difficulty | MontyR | ANSYS Meshing & Geometry | 4 | July 23, 2011 21:46 |
Meshing problem trailing edge of blade | ben-18 | ANSYS Meshing & Geometry | 1 | July 13, 2011 10:39 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Aerofoils/blades with rounded trailing edge. | Sergei Chernyshenko | Main CFD Forum | 6 | July 26, 2000 05:10 |
trailing edge problem | Kuo Wei-Jen | Main CFD Forum | 2 | April 14, 1999 10:09 |
