FSI
Old   January 19, 2006, 10:56
Default FSI
ms
I am wanting to run an FSI simulation using a commercial CFD hopefully CFX, maybe fluent to an in house structural code. I can export my pressure from the cfd and import to the structural but am struggling to get my new geometry back into my cfd code and then re-mesh?
Any ideas how I could go about this? Would adaptive or dynamic meshing do the job? Do I have to restart the simulation at each new time step with a new geometry?
Old   January 19, 2006, 15:00
Default Re: FSI
Luca
As I know, CFX can do that witout any problem. What you mean is the definition of a interface procedure for data interpolation beetween CFD and structural model. If you want to do that in FLUENT maybe you can look on the net for MPCCI. If you want to create your own procedure I'd suggest downloading my paper at http://www.aero.polimi.it/~quaranta/publi.html
presented at IFASD 2005. Hope it helps Luca
Old   January 20, 2006, 04:21
Default Re: FSI
ms
I think MPCCI will be too expensive for my research, an ideas of any alternatives out there?
Old   January 20, 2006, 09:22
Default Re: FSI
Luca
Unfortunately no more ideas. You should write your own procedure. In the article you find in my paper there are some references. Luca
User-defined force transfer across FSI interface vivekcfd CFX 7 March 10, 2010 20:43
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 04:14
fsi sun Siemens 8 January 19, 2009 23:17
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
FSI on a Rotating Structural Model drgolf CFX 9 August 30, 2007 12:08
