question on ray tracing
Old   February 8, 2006, 05:52
Default question on ray tracing
Ramesh
Hallo members, I am working on 3D grid deformation. I am looking for a an algorithm, using which i should be able to find the element in which my nodes gets displaced. To make it more clear. Initially i start with a structured 3D grid and then deform my geometry whereby all my nodes gets displaced. After that with respect to my original structured grid, i need to find the element where the node got displaced. If anybody has some information then kindly let me know. Ramesh
Old   February 8, 2006, 18:19
Default Re: question on ray tracing
AnotherCFDUser
Not sure if I understand completely.
But to find a point in a grid you can follow this procedure:
For each element :
Divide the element into tets (3D) or triangles (2D).
For each tet or triangle perform the test described at http://stevehollasch.com/cgindex/geometry/ptintet.html
If the test is true then you have found the element in which the point is located and can stop the search.
WARNING: This can be expensive, but can be reduced in cost using a random walk search algorithm rqather than stepping through the elements in turn.
Old   February 9, 2006, 03:48
Ramesh
thanks for the link, it will be helpfull i believe...perhaps if you have any more algorithms, kindly post it across Regards Ramesh
Old   February 9, 2006, 05:23
Renato.
at the same link "AnotherCFDUser" posted there's a bunch of computer graphics algorithms. Including those relatet to ray tracing, take a look http://stevehollasch.com/cgindex/index.html
solar ray tracing and do irradiation ericguangzhou FLUENT 2 September 25, 2015 19:26
Ray tracing gorlcjstk FLUENT 0 August 4, 2011 08:04
Can DO model + Solar ray tracing model the collimated light beam(parallel light) zhang.limin Main CFD Forum 0 August 3, 2010 13:06
solar ray tracing yosr FLUENT 0 January 29, 2009 10:40
Ray tracing Mark FLUENT 0 June 25, 2003 06:30
