January 7, 2013, 05:09 |
Pipe flow developing too quickly
Rep Power: 15 |
I am simulating the development of a pipe flow. At the inlet, uniform velocity is imposed and it reaches a parabolic profile somewhere downstream and becomes fully developed. My problem, however, is that, the location at which it reaches the parabolic profile is too close to the inlet (on comparing with results from journal papers). Any suggestions on why this might be happening? Thanks in advance, Qrie |
January 7, 2013, 05:36 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
what about your Reynolds number? |
January 7, 2013, 06:04 |
Rep Power: 15 |
I have tried it for Re 10 and 100. Encountered the same problem in both cases.
January 7, 2013, 06:43 |
Rep Power: 71 |
January 7, 2013, 06:47 |
Rep Power: 15 |
I meant I get fully developed profiles much earlier in both cases compared to the respective values in the journal paper. Yes, the solution matches the Poiseuille parabolic profile.
January 7, 2013, 07:30 |
Rep Power: 15 |
And I checked now, and turns out - yes for both I get it at the same x/D!
January 7, 2013, 07:41 |
Rep Power: 71 |
January 7, 2013, 07:43 |
Rep Power: 15 |
Ok, will do that. I have given convective outflow bcs.
January 7, 2013, 08:00 |
#9 |
Rep Power: 71 |
Assuming that the code has no bug, what about the grid sizes and discretization of the convective terms? If your grid is too coarse and you are using first order upwind, maybe you have so much artificial viscosity that overcome the real one... but I am more for some bug ... |
January 7, 2013, 08:06 |
#10 |
Rep Power: 15 |
The code uses second order central differences, and isn't coarse. I have refined it to the same size as in the paper. Its a direct solver, no artificial viscosity is used. Thanks, I will check for any bugs. Have already done that actually. Is there anything else that might be causing this?
January 7, 2013, 10:49 |
#11 | |
Rep Power: 71 |
January 8, 2013, 04:30 |
#12 |
Rep Power: 15 |
Yeah velocity is not diverging, however if I increase the pipe length too much it does.
development length, pipe flow |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 16:41 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 08:36 |
outlet boudary condition for a flow in the pipe | Atit | CFX | 2 | November 9, 2004 17:43 |
stepped pipe flow | Tom Cloutier | Main CFD Forum | 0 | April 20, 2003 13:19 |
