Time step for implicit solver
Old   March 24, 2013, 09:27
Default Time step for implicit solver
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I am simulating low pressure turbine unsteady flow and I have couple of questions:
1. How to decide time step for the implicit solver?
2. Do we need to satisfy CFL < 1 for implicit solver?
3. Why implicit solver is preferred in commercial codes and as I understand for unsteady flows explicit solver would be better option.
4. Or explicit solver is only efficient in LES where turbulent scales to be resolved are the same order as the time step dictated by CFL < 0.2 condition?
5. For the same geometry and flow, time step is inversely proportional to Reynolds number?
Far is offline   Reply With Quote
Old   March 24, 2013, 10:10
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
A CFL number smaller than 1 is a stability constraint for some explicit solvers which does not apply to the implicit ones.
This partly answers question 3, because with the implicit solvers, the timestep size can be chosen according to the flow considered and does not have to fulfill a CFL criterium.
Since a CFL number below 1 is a good guess for the timestep in LES, the advantage of implicit solvers allowing for larger timesteps becomes irrelevant, since the timestep has to be small anyway.
According to Kolmogorovs turbulence theory, the timescale of the smallest eddies is proportional to Re^{-1/2}. Yet this is only relevant for DNS.
In a LES, there are different approaches to estimate an appropriate time step size, like CFL<1 for example.
flotus1 is offline   Reply With Quote
Old   March 24, 2013, 15:53
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
the choice is driven by the numerical stability as well as accuracy requirements.... often, implicit scheme are not "pure", in the sense they are mixed in an implicit and an explicit part. For example, a classical integration used in DNS/LES is the Crank-Nicolson for the diffusion and the Adams-Basforth for the convection. This result in a conditionally stable scheme that is not stable only under the satisfation of the cfl<1 condition. It exists a stability region in the cfl-Reh plane.
FMDenaro is offline   Reply With Quote
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
