stream line at low Re, help
Old   June 4, 2006, 08:59
Default stream line at low Re, help
joe
hi, i found that the stream lines at Re~=5 are not symmetry to the axis along the flow, but in textbook,we are told it is symmetry at low Re. can u give me some hint?
regards joe
Old   June 5, 2006, 08:22
Default Re: stream line at low Re, help
Andrew Hayes
Did you check your velocities? Also, you need to tell us what exactly you are doing?
Old   June 6, 2006, 01:49
goodegg
i'm cheching the sepatration and vortex dimension behind the cylinder, separation occurs at Re~=5, and i thind the streamlines are symmetry here.
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
