Tetrahedral geometry
Old   July 20, 2006, 08:17
Default Tetrahedral geometry
Dr.Nick
Hello!
I'm working on 3d LES FV code for NS. I've already made a fine solver for structured grid, and now my task is to do the code for tetrahedral elements (unstructured grid). And now i'm facing the problem of calculating geometry properties of a tetrahedra. I know that many people already did it b4, so i hope you can help me with links on computational geometry or good advices.
Thank you in advance!
Old   July 24, 2006, 11:26
Default Re: Tetrahedral geometry
ganesh
Dear Dr. Nick,
You could refer to the book by Hirsch, which gives the area normal and volume computations for different elements
Regards,
Ganesh
Old   July 25, 2006, 12:10
Nico
Ferziger/Peric page 224 (1st edition) should be give some ideas.
Old   July 28, 2006, 00:31
Dr.Nick
Thanks!, though I already found the solution by reading my old university lectures on 3d geometry and topology =)
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 13:02
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
