Sloshing pendulum analogy
Like Tree1Likes
  • 1 Post By ybav223
Old   July 19, 2013, 02:07
Default Sloshing pendulum analogy
Anonymous
ybav223 is on a distinguished road
Hello All,
I am trying to run a simple liquid sloshing case. Initial liquid level is about 40% diameter of simple sphere. The CFD run is setup such that the liquid level initially is inclined and after one time step it sloshes under influence of gravity (acting downwards). My intention is to calculate the dominant frequencies. This can be obviously obtained by FFT of time history of force acting sideways on the tank walls. Apart from this I would like to calculate the sloshing mass and fixed mass (ref: Pendulum slosh analogy). It would be great if anyone can provide the relations to calculate the sloshing/fixed masses and subsequent pendulum lengths.
Thanks you
brahma likes this.
ybav223 is offline   Reply With Quote
Old   August 14, 2013, 02:56
Default Sloshing analogy
brahmendra S Dasaka
brahma is on a distinguished road
I am also trying to do sloshing in a rectangular tank. But the loading is harmonic acceleration. I am new to CFD and would like to do FSI. Can you please provide material for pendulum analogy for sloshing if you get the solution.
Regards.
Originally Posted by ybav223 View Post
Hello All,
Thanks you
brahma is offline   Reply With Quote
Can RANS turbulence model be used to check the validity of Reynolds Analogy? keryfluid Main CFD Forum 0 April 22, 2013 22:48
Force Window and sloshing mass satellite_control FLOW-3D 0 October 6, 2011 09:04
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 20:13
Calculating Sloshing mass in a cylinder satellite_control FLOW-3D 0 June 20, 2011 05:34
Udf for sloshing problem D.Martelli Fluent UDF and Scheme Programming 0 December 9, 2009 11:21
