August 22, 2013, 11:49 |
Meshing topology for heat transfer over ribs
I am solving "Numerical Simulations of Flow and Heat Transfer over Rib-Roughened Surfaces"
For this purpose I have built type 2 meshing shown in Image 1 (type2 and its closeup view shown in image2). Second reference uses similar case and study the flow and heat transfer over rib-roughened surface using Type 1 meshing as shown in image1. My question is "Which mesh topology is better". Reference 1 http://www.ercoftac.org/fileadmin/us...2/case72d.html Reference 2 http://cfd.mace.manchester.ac.uk/twi...al_CDFSC09.pdf Type 1 and 2 closeup view of type 2 blocking |
August 22, 2013, 11:55 |
Filippo Maria Denaro
Rep Power: 71 |
I think that the answer depends on the formulation, model and accuracy of the scheme you want to use,...
How about the scales you want to solve? At a first look I would use mesh 2 |
August 22, 2013, 12:04 |
I will use finite volume, second order accurate solver (Fluent, CFX or Star CD etc). Turbulence models to be used are K-epsilon and V2F. I need to compare flow variables and nusselt number with the Reference 1 data. I need that CFD data should be highly accurate
August 22, 2013, 12:24 |
#4 | |
Rep Power: 71 |
Furthermore, BC setting can be quite difficult in terms of modelling variables owing to the series of recirculating region. How about the range of Reynolds and Peclet numbers? Maybe a comparison with LES in Fluent (dynamic model) can be useful if not computational expensive |
August 23, 2013, 06:28 |
Jarda Chlup
Rep Power: 12 |
Type 2 is better because of angles of elements. This angle is close to 90 degree, what is better for convergence and accuracy of calculation.
August 23, 2013, 06:53 |
Alex
Rep Power: 46 |
Personally, I would choose option 2.
Option 1 has some mayor drawbacks
August 26, 2013, 04:22 |
I see why option 2 is having more acceptance but:
1) If accuracy is the main concern, especially in the near wall zone (i guess), i don't get how 45° skewed cells can outperform square cells in option 1 2) As the problem seems 2D (and because accuracy is the main concern) the number of cells should not be a problem for option 1. For 3D cases this might not be true and, actually, if i had to perform a LES computation with several cubes, option 2 might be mandatory. 3) For option 1, unnecessary high aspect ratio cells are only present far away from the region of interest. Still, they shouldn't be as problematic as the skewed cells near the walls due to option 2 4) In my experience for this case, turbulence modeling is far more important (go for v2f) as long as the grids are "fine enough" 5) Some numerical options in Fluent might be very sensitive to option 2 grid (e.g., gradient computation method). Hence, if you go for it, you might also want to check for other discretization options; this should be less relevant for option 1. If i remember correctly, CFX uses a node based Finite Volume approach, i don't know if it might have the same problems (but i guess so). 6) Node distribution in case 2 is clearly not optimal, with several jumps in cell size in the most important part of the flow. This is not a judgement on the grid, but an observation on the fact that is far more difficult to create an optimal grid for case 2 than case 1 At the end of the day, if there are no pathological behaviors in the solver (to be checked) i think that, for sufficiently refined grids, both option will eventually give you a sufficiently accurate answer (sufficiently meaning within the accuracy of the turbulence model) |
August 30, 2013, 13:20 |
#9 |
Solved another example with same mesh topology. some observations are:
1. Mesh topology is good enough 2. decreasing Y+ below 0.5 and doubling the mesh size has no effect on heat transfer calculations 3. SST is bettar than V2F model 4. All other models are not good in predicting heat transfer http://www.cfd-online.com/Forums/flu...-transfer.html |
August 30, 2013, 13:59 |
#10 |
Stuart
Rep Power: 25 |
Far,
Regarding the O-grid in mesh option 2, how did you determine/justify the size of the O-grid in relation to the size of the cube? You say about getting the y+ of 0.5 but can you comment on what the node expansion rate inside the O-grid was and why you chose such a value? Also can you comment on why you chose such large cell area transitions from the last O-grid cells to the first right-angled cells (I've highlighted your image)? Experience and literature for me says that area (or volume in 3D) cell expansion should not be more than 20% (30% at a push). I'm interested in this topology because I'm looking at something very similar, but not from a heat transfer point of view, for my PhD (3D and completely difference objectives) and I like to justify all my mesh features (node quantities, expansion rates etc). I'm currently running some Fluent cases for my PhD also on the simplest topology, like your option 1. Thanks |
August 30, 2013, 14:12 |
#11 | |
yes you are correct expansion should not be more than 20-30%. Maximum mesh expansion inside the o-grid is not more than 1.1-1.2 The mesh shown in pic is not the representative of the mesh i am using in my computations. It was just give to an idea about the mesh topology. The actual mesh i am using is here and you will notice that there is no jump in mesh at any point. Edit closeup view of mesh inside the ogrid Last edited by Far; August 30, 2013 at 14:20. Reason: adding image # 4 |
August 30, 2013, 14:41 |
#12 |
Stuart
Rep Power: 25 |
Thanks for that Far.
How did you decide on the size for the O-grid or did you leave to the default size when made in ICEM? |
August 30, 2013, 14:55 |
#13 |
Based on just visuall appreance, no calcualtion for boundary thickness is made. But I am sure it will be sufficient
50 layers are used in boundary layer based on my expereince with transition simulations. |
August 31, 2013, 07:36 |
#14 |
Can any body help me in getting article:
Baughn, J.W., Yan, X., 1992. Local heat transfer measurements in square ducts with transverse ribs. ASME National Heat Transfer Conference. |
November 8, 2013, 00:08 |
meshing of duct flow with ribbed surface 2D
#15 |
nilesh
hello sir
I am new to ICEM so please help me to mesh the surface properly please reply me in some what detail as i am fresher to this software |
Volume 1 has invalid topology for mapped brick meshing | georgewar | ANSYS | 0 | July 24, 2011 16:02 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
additional variable mass transfer in CFX5.6 | john | CFX | 1 | February 14, 2004 00:30 |
