what is the meaning of white noise
Old   November 14, 2006, 06:19
Default what is the meaning of white noise
ztdep
Hi: What is the meanin of white noise. Regards
Old   November 14, 2006, 06:44
Default Re: what is the meaning of white noise
Andrew Hayes
static
Old   November 14, 2006, 06:59
Mani
The notion of "white" refers to a particular form of the frequency spectrum. If I remember right, white noise exhibits a continuous, wide range of frequencies with uniform power (or amplitude?), i.e. each frequency from 0 to infinity contributes equally to white noise. You won't hear any distinct sound out of this noise. I am guessing that the name "white" is in analogy to light: White light consists of a continuous range of frequencies between (not including) UV and infrared.
How are you using this for CFD?
Old   November 14, 2006, 08:08
Ben
Isn't it a song by procal harem?
Old   November 14, 2006, 09:02
Harish
Sometimes the term white noise and pink noise are used by authors in papers on turbulence ( some that i have come across).A good explanation of different noises is provided in wikipedia.
Old   November 17, 2006, 04:14
M.SURESH KUMAR
Can be used for finding architectural acoustics
Broadband noise problem Ric_85 FLUENT 0 September 28, 2010 18:42
Boundary Layer Noise Source Model Andrew FLUENT 0 January 12, 2009 22:47
Turbo noise macro Barri CFX 0 May 21, 2008 09:26
turbine noise naser FLUENT 0 December 3, 2004 13:37
Noise Heinz Wilkening Main CFD Forum 13 January 19, 2000 05:22
