Rought estimation of dissipation energy
Old   December 10, 2006, 20:57
Default Rought estimation of dissipation energy
MC
I am trying to estimate energy disspation and the corresponding heat enrgy from the large scale characteristics of turbulent flow. Especially, heat engergy from the fluid flow. I know exact calculation of it is almost impossible but, I need to estimate roughly.
Problem : Dissipation energy of flows in a moved large cube
Dimension : L*B*H = 50m * 40* 30m Filling ratio : 95% of the height
Large scale velocity u ~ 5m/s Dimensional scale L ~ 50m
So, turbulent dissipation rate epsilon ~ u^3/L = 2.5 (Joule/(kg*sec))
Effective Mass in a cube ~ 4250 ton (because upper part of the fluid in a cube would be excited)
Finally, total energy dissipation 1) m*epsilon ~ 4250 ton * 2.5 = 10625 kW
If this energy could be changed to the heat energy 2) Q=4250 ton * 9,540Kj/KgK * dT ~ 10625MW
temperature difference dT ~ 0.00026
But, I think the energy of 10625kW looks too much. So, please comment the above 1) and 2).
Thank you for your valuable comments in advance.
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Boundary Conditions for Turb. Energy + Dissipation sebastian Main CFD Forum 0 May 5, 2008 03:32
Energy dissipation and Drag coefficient Freeman Main CFD Forum 10 January 27, 2006 07:42
turbulent kinetic energy and dissipation panneerselvam.R CFX 1 July 22, 2005 01:55
calculation of (turbulent) dissipation energy ? max Main CFD Forum 3 August 18, 1999 09:42
