NRBC: Sponge layer approach
Old   November 7, 2007, 09:44
Default NRBC: Sponge layer approach
jinwon park
I am solving 2D compressible flow modeled by Euler equation. In doing, it is necessary to impose the NRBC along boundaries to prevent spurious reflection from boundaries.
Based on the literature, I found that the sponge layer approach is simple to implement and provides relatively clean solution with no wave reflection back to the domain.
The implementation of the layer along four boundary faces was straightforward. However, for four corner areas, that was not as trivial as others. In below figure, we can see the corner area in implementing the sponge layer. If anyone have had such experiences, could you let me know how to define such corners?
Thanks in advance.
|diff | Sponge layer(easy)
|_____|___________________
|easy | Problem domain
Old   December 5, 2013, 07:33
sci
sci is on a distinguished road
I'm also working on sponge layer. but unfortunately I couldn't find much information about it. Could you please introduce a reference to me?
sci is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 20:05
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
sponge layer shuo Main CFD Forum 0 April 1, 2010 00:39
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
