Geometry vs flow direction
Old   December 2, 2013, 06:41
Question Geometry vs flow direction
violetsaka is on a distinguished road
I'm new to CFD.
I have the following question:
Is the flow direction dictated by the geometry you have generated?
For instance, if you have generated a vertical circular pipe will the flow be automatically vertical (either upward or downward) on the simulator? Or it depends if you consider gravity?
Sorry for what may seem like a stupid question and thank you in advance for your help,
VK
violetsaka is offline   Reply With Quote
Old   December 7, 2013, 18:09
Lefteris
Aeronautics El. K. is on a distinguished road
I take it you're interested in an internal flow, right?
The flow in the pipe will be driven by a pressure difference. Now whether the flow goes up or down in your pipe, it depends on this pressure difference. If the fluid is not a gas but a liquid, you need to consider body forces too.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
direction, flow, geometry, gravity
FLuent simulation of taylor couette flow of concentric cylinder geometry. rshbhb FLUENT 53 November 5, 2014 19:07
Can we get two different flow regimes in a single geometry? TQIM STAR-CCM+ 2 November 25, 2012 23:45
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
Flow direction in Buoyant flow Nav CFX 4 June 30, 2008 00:50
specifying the flow direction in periodic boundary joanna FLUENT 2 February 27, 2006 21:09
