December 17, 2013, 07:07 |
A room with a porous surface
tmeysam92
Rep Power: 14 |
Hi There is a room with an inlet and an outlet and a porous surface(the green surface in the fig.) which air flows from the inlet surface(which is a part of the room's ceil) through the porous surface and exits from the outlet. how I can model the porous surface(the green one) and what parameters I need and how calculate them? Regards |
December 17, 2013, 15:01 |
Usually a pressure drop over velocity curve is needed.
fluent 14, porous body |
[ICEM] Surface mesh not sticking to surface | holtwong | ANSYS Meshing & Geometry | 2 | April 20, 2023 08:28 |
surface reaction, porous media | Ali | FLUENT | 2 | March 31, 2016 17:26 |
[snappyHexMesh] Snap Precision to a STL Surface | malaboss | OpenFOAM Meshing & Mesh Conversion | 16 | July 26, 2013 01:44 |
[snappyHexMesh] Add additional boundary layers to complex stl surface | tobijingles | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2011 10:45 |
how to set no-slip on the surface of porous media | Nanjiang | FLUENT | 0 | August 7, 2007 13:15 |
