February 2, 2014, 11:42 |
hemodynamics: modelling of tapered aorta
sushant kulkarni
model flow through descending aorta including the effects of vessel taper and outflow through tributaries. assume flow to be "inviscid and steady". for this purpose aorta is represented as vessel with linear taper along which 1o tributaries are distributed. (assume 5 on each side). each tributary is assumed to have an outflow "q" (taper effect neglected). Flow rate is entering at station 1 is Q .i.e at the entry point. analyze the following cases (use Bernoulli equation)
1. A2 = A1/2 and q = 0 2. no taper and q = Q/20 3. A2 = A1/2 and q = Q/20 4. suppose one of the tributaries is occluded, as in arterial occlusion, analyze the case 1,2 and 3, have attached figure for reference. |
bernoulli's equation, hemodynamics |
kOmegaSST without turbulence modelling of the flow around geometry | CFDnewbie147 | OpenFOAM Running, Solving & CFD | 7 | December 5, 2013 07:29 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Modelling unsteady 2D aerofoil drag | xlxc34 | Main CFD Forum | 0 | June 24, 2011 04:42 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
how to ensure that your modelling is correct | rvndr | Main CFD Forum | 7 | March 1, 2004 12:21 |
