wall y-plus problem: unable to manage between 30 to 300..kindly help..
Old   February 8, 2014, 01:18
Default wall y-plus problem: unable to manage between 30 to 300..kindly help..
maaz ahmad
maaz is on a distinguished road
i am pasting the problem link here, below,,, images also attached here...
http://www.cfd-online.com/Forums/mai...-building.html
maaz is offline   Reply With Quote
Old   February 12, 2014, 09:54
Lefteris
Aeronautics El. K. is on a distinguished road
What turbulence model do you plan to use?
Are you going to use FLUENT (or CFX) for you analysis?
If so, Menter suggests to follow a y+=1 strategy and use a y+_insensitive turbulence model. I think that most of their models are like that now but take that with a pinch of salt as I'm not absolutely sure.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   February 13, 2014, 22:41
maaz ahmad
thanx for response....i am using fluent software...and solver is std k-epsilon..with std wall functions (not enhanced)...actually the problem starts when i once run problem....my values of pressure coeff. remain good but y plus falls below 30...as i alter the mesh of those places showing y plus less than 30, it starts showing absurd values of pressure coeff. ,,,so when i control the y plus, pressure coeff becomes absurd...this is the problem.....so i need help.....
Old   February 14, 2014, 13:51
Lefteris
Maybe your mesh is too coarse generally. If the mesh was good enough then you would get the Cp right and you wouldn't have the correct Cd. I would try to refine the mesh and go for y+=1 and use enhanced wall treatment.
Lefteris
Old   February 14, 2014, 23:13
maaz ahmad
actually when i refine the mesh to get values of y+=1, gambit crashes with the error: out of memory..so i cant take that much fine mesh..if you can suggest me anything for this ..please..
Old   February 15, 2014, 20:05
Lefteris
I don't know if there's going to make much difference but try y+<5 and enhanced wall treatment in Fluent. If you gambit crashes again, go again for y+>30 and standard wall functions.
However, I believe that you should refine your grid generally, not just near the walls.
Lefteris
Old   February 21, 2014, 04:41
maaz ahmad
my ske and rng values are showing much difference ...anyone can point out the reason...
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
problem in using of additional variable in wall velocity adsladsl CFX 10 May 31, 2015 19:29
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Two Sided wall Problem Mk1987 ANSYS Meshing & Geometry 0 March 26, 2010 13:09
moving wall BC problem Sourabh Main CFD Forum 1 August 8, 2006 07:47
