March 21, 2015, 01:40 |
Multi-Phase Flow... Help
Alex
I generated the mesh of a 1-dimensional flow (-z direction) lance which is compounded to a completed meshed duct running industrial boiler flue gas. I want to simulate a time-dependent compressible turbulent flow of the gas passing through the duct and a lagrangian dispersed solid particles flow passing through the lance into the duct to eventually mix the 2 flows together. After meshing the generated geometry in the Salome, how can I run the algorithms using openfoam. In other words, which solver code should we use to input the parameters of the differential equations and the multiphase flow boundary conditions in order to simulate a multiphase flow model.
I am looking to use Lagragian Particle Tracking Method and Turbulence Flow Model (SimpleFoam) algorithms together. What are the proper files and folders to work with? Can you email me a layout or a tree structure that would explain to me how to couple both algorithms to run in openfoam? |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Multi phase flow VS Free surface flow | Kiffer | Main CFD Forum | 0 | November 17, 2012 00:17 |
High Speed multi phase flow | jonita Macyte | Main CFD Forum | 0 | March 19, 2010 06:46 |
how 2 freeze 1 phase flow field & start lagrangian | KK | CFX | 5 | February 14, 2008 16:48 |
low speed compressible two phase flow?? | cat | CFX | 0 | November 15, 2005 07:59 |
