February 20, 2007, 06:28 |
propeller in non-uniform flow
Dear friends, i am trying to compute a marine propellers in non-uniform oncoming flow. The propeller is inside a cylindrical rotating mesh, with the inlet at a couple of diameters haead of the propeller itself. What should I impose at the inlet to have at the propeller plane the nominal wake measured in the towing tank? If I impose the nominal wake at inlet it will reach the propeller partially diffused. How can I face this problem? thanks
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 07:32 |
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls | david39 | OpenFOAM Running, Solving & CFD | 6 | January 18, 2011 11:49 |
laminar pipe flow with buoyantSimpleRadiationFoam and janafThermo crashes | Fabian | OpenFOAM | 1 | September 29, 2010 11:38 |
Channel flow: Inlet pressure AND uniform velocity? | frmap1 | Main CFD Forum | 0 | April 15, 2010 10:32 |
