coupling equations
Old   March 19, 2007, 12:24
Default coupling equations
mettler
I solved a 2-d flow problem for the flow field first and then used the veloocties in the heat transfer equations. My tmeperature rise was only a few degrees, therefore, I did not re-solve the flow field equations due to the very small changes in the thermal properties of the fluid. My question is; Is this correct or is it necessary for me to couple the equations?
thanks
Old   March 19, 2007, 20:00
Default Re: coupling equations
otd
Is a few degrees important to your process or product? Will it give an inferior heat treat to a metal?
As to the coupling, why not just try it? If the flow patterns don't change (you define how small the change must be before it can be ignored), the temperatures after the second pass will change by an ignorable amount.
You'll learn a lot more by trying it than asking for a rule to follow.
Old   March 19, 2007, 20:46
otd
My reply above was sort of sharp - sorry about that.
But, if you can spend the time, you'll learn a good bit by correcting the properties for the temperature change and re-running the problem. Or, if your fluid is a gas, try the problem using a compressible algorithm.
Good luck.
Old   March 20, 2007, 06:19
Ibiro
Based on what I remember from coursework: for low Mach numbers, the energy equation is decoupled from the continuity and momentum equations so that you can first solve the continuity and momentum equations and use this solution to solve for the temperature distribution via the energy equation. I.e., for low Mach, there is no exchange between kinetic and internal energy. However, I don't think this holds if bouyancy is included. For instance, if you have a high temperature boundary surrounded by low temperature ones, free convection is going to occur and can significantly affect the temperature distribution. In this case I believe the equations are coupled. Hope this helps.
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 03:19
do_while loop for coupling two equations (convergence criteria?) mhassani OpenFOAM Programming & Development 3 February 28, 2011 11:35
coupling mass transfer and navier-stokes equations m.saadatmand Main CFD Forum 1 July 11, 2010 04:40
Coupling equations by mapping between 2 different meshes benk OpenFOAM 0 March 16, 2010 15:38
Coupling of multiple equations akidess OpenFOAM Running, Solving & CFD 1 July 29, 2009 20:49
