March 22, 2014, 11:39 |
Boundary Conditions for a flow in pipes
Masoud
Rep Power: 12 |
Hi dear friends
What is boundary conditions(inlet and outlet) that we should use in a compressible flow in a pipe and what is your reference? Kindly flow is subsonic. regards Last edited by masoudmohammadian; March 23, 2014 at 14:47. Reason: I made mistake because the flow is compressible not incompressible |
March 23, 2014, 07:34 |
sanam pudasaini
Rep Power: 12 |
You can use either mass flow rate or velocity as inlet boundary condition and relative pressure as outlet boundary condition. But first set your reference pressure in order to use relative pressure.. Hope it helps
March 23, 2014, 07:57 |
Vishnu C
Rep Power: 12 |
For inlet give velocity inlet condition and for outlet pressure outlet
March 23, 2014, 09:09 |
Masoud
Rep Power: 12 |
Hi dear friend
Is it correct to use velocity when density is not constant? what is your reference of your answer? |
March 23, 2014, 09:11 |
Masoud
Rep Power: 12 |
thanks a lot my friend. I need the reference for your reply such as book, paper,...
March 23, 2014, 10:20 |
#6 | |
Vishnu C
Rep Power: 12 |
For reference you can read boundary condition section in Fluent manual. |
March 23, 2014, 14:46 |
Masoud
Rep Power: 12 |
Thanks my dear friend
Sorry I made mistake because my flow is compressible regards |
March 24, 2014, 00:12 |
Rep Power: 14 |
Just a correction, for incompressible flow, density is not constant (atleast, not always).
Our (mu/rho) should be constant.
Best wishes, Somdeb Bandopadhyay |
March 24, 2014, 01:15 |
#9 |
Masoud
Rep Power: 12 |
hi dear friend
I didn't get your answer regards |
March 24, 2014, 01:27 |
#10 |
Rep Power: 14 |
What I meant to say is:
When you model incompressible flow, density is not always a constant variable. Its the kinematic viscosity(=dynamic viscosity/density) which is constant. For Low Reynolds number, flow most cases, the density'll not vary much.However, when you go to the moderate Re regime, most likely your density'll vary (depending of the fluid property though). So, as long as you keep kinematic viscosity constant, you are in "safe zone". Whereas keeping a constant density may lead to error. that's all
March 24, 2014, 01:54 |
#11 |
Masoud
Rep Power: 12 |
but you know, my flow is compressible with Ma No. about 0.8
March 24, 2014, 02:12 |
#12 |
Rep Power: 14 |
I was referring to the other post actually, where it was stated that incompressible flow=constant density..that's all(that's why i used "just a correction" phrase)
March 24, 2014, 02:17 |
#13 |
Masoud
Rep Power: 12 |
thanks a lot dude and sorry for any inconvenience
March 24, 2014, 12:54 |
#14 |
For Compressible flow through a pipe you can give Total Pressure at inlet and static pressure at outlet and from the stagnation static relations we can estimate the flow Mach number or the other way around if you want a particular Mach Number then calculate the relations accordingly with atmospheric pressure as reference.
March 24, 2014, 22:13 |
#15 |
Vishnu C
Rep Power: 12 |
But numerically when we solve incompressible flow equation density term will be treated as constant and removed from momentum equations so i told him in terms of CFD(since he is working in it), but when comes to flow physics what u told is correct.
March 24, 2014, 22:18 |
#16 |
Rep Power: 14 |
To add to my point:-
http://www.sciencedirect.com/science...21999108006748
March 25, 2014, 01:45 |
#17 |
Vishnu C
Rep Power: 12 |
OK, i don't think all solvers use this.
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Boundary conditions low Mach number flow | lost.identity | Main CFD Forum | 0 | November 28, 2010 04:44 |
boundary conditions for boundary layer flow | A. Al-zoubi | CFX | 0 | November 3, 2007 07:11 |
Internal flow simulation boundary conditions | Kishore | FLUENT | 1 | July 10, 2007 11:42 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
