3D NACA0012 with vortex generator
Old   April 5, 2007, 09:30
Default 3D NACA0012 with vortex generator
Franny
HI all, i m trying to model a 3D NACA0012 at angle of attack = 15deg with a forward wedge on it positioned just upstream the separation point.Unfortunately i haven t got good reults for convergence using high resolution.Then i have tryied blend factor 0.5, but the quality is not good.I can t see the development of the boundary layer at all, plus it looks like the separation is totally disappeared.It looks like the inflation layer are not visible in the post processed results.I m running now blend factor 0.75 and i have increased the infaltion layer thickness and number.What do you think i should do? Thank you for any advice.
Franny
Old   April 5, 2007, 09:31
Default Re: 3D NACA0012 with vortex generator
to
Factor to blend what ?
Old   April 5, 2007, 09:43
Harish
Are you using a commerical software or home developed code.What kind of grid generation, numerical discretization ,boundary condition do you use ?.
Please be specific about all the details of your simulation.People cannot help you without knowing the details.How many points do you use in the boundary layer.A simple calculation of delta ~ 1/sqrt(Re),can be used to estimate the size and then you can determine the number of points to use according to your numerical scheme.
Old   April 10, 2007, 18:09
Franny
Thank you for your answer.First of all I would like to apologize for my bad english,it is probably not enough to write here and to be understood.Anyway, i really appreciate all the people that helped me already, and please do not be too sarcastic with others as one day you could need help as well.Thanks for now and KIND REGARDS. Franny
O-grid generator for NACA0012 Prashanth Main CFD Forum 1 October 29, 2009 23:11
NACA0012 gird generator Prashanth Main CFD Forum 5 May 1, 2009 04:20
Air-Jet Vortex Generator, request for some papers ROOZBEH FLUENT 0 July 12, 2008 10:28
Air-Jet Vortex Generator, request for some papers ROOZBEH Main CFD Forum 0 July 12, 2008 10:27
vortex generator Pao Main CFD Forum 0 June 3, 2003 09:25
