April 14, 2014, 15:38 |
Question abt the CFX tutorial regarding scaling of the rotor blade row!
Minoo
Rep Power: 12 |
I have a very basic question. In the axial turbine example in the cfx tutorial, the rotor has 113 blades and the stator has 60 blades. The blade row is scaled with the factor of 0.942 (using two blades and one vane). However the blade row is not actually scaled, since the total number of blades used, based on which the flow passage is created, are still 113 while I expected it to be approximated to 120! Could anyone be so kind to explain this to me?
Meshing or Topology generation error in TurboGrid? | jetcheve | CFX | 21 | July 24, 2021 09:08 |
[Other] TurboGrid - problem with trailing edges ending with hub/shroud curve | TTM | ANSYS Meshing & Geometry | 8 | February 16, 2020 07:11 |
Importing ICEM mesh in TurboGrid | ayothicfd | Main CFD Forum | 0 | October 8, 2011 10:23 |
[Other] exchange of parameter values between TurboGrid and DesignModeler in Workbench | la7low | ANSYS Meshing & Geometry | 2 | February 21, 2011 15:12 |
Axial blade simulation, TurboGrid a must? | Gentry | CFX | 1 | March 19, 2009 10:20 |
