areas of application of numerical solution procedures
Old   May 10, 2014, 10:41
Default areas of application of numerical solution procedures
maybee is on a distinguished road
hi,
very popular numerical solution procedures are
- 1.finite difference method fdm
- 2.finite element method fem
- 3.finite volume method fvm
Which are the main areas of application of the different methods? Which types of differential equaitons in terms of dimensions that have to be solved are they good for?
1. What are the typical areas of application here?
2. I ve read that the finite element method is mostly used in solid body analysis. What are the typical differential equations respectively dimensions (like tension, displacement, temperature) solved for with fem?
3. As far as I ve read the typical area of application are processes where conservation equations are most important like in fluid mechanics.
greetings
maybee
maybee is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
Convergence problem suthichock Main CFD Forum 27 May 11, 2009 07:05
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
