Boundary Conditions Of Discrete Adjoint Method For 2D NS Equations
Old   May 30, 2014, 00:48
Unhappy Boundary Conditions Of Discrete Adjoint Method For 2D NS Equations
Ashkaari
Ashkaari is on a distinguished road
Hello everyone, I've been working on the adjoint based grid adaptation for viscous flow.But my adjoint solver doesn't work out well.
Here is the problem, back in the flow solver, no-slip and isothermal wall conditions were applied.
At wall,u=v=0,E=ρT/(γ-1)=Kρ.
And the residuals of momentum and energy equations were all zeroed out(R2=R3=0).
The adjoint equations is,
(әR/әW)Tψ=әI/әW.
ψ=[ψ1,ψ2,ψ3,ψ4] is the adjoint solution.
(әR/әW)T is the transposed Jacobian with W=[ρ,ρu,ρv,E],
I is an output function like lift or drag coefficient.
For a wall node i, by hand differentiation:
әR1/әW=[0,nx,ny,0],
әR2/әW=әR3/әW=[0,0,0,0],
әR4/әW=K*әR1/әW.
The transposed Jacobian becomes [0,0,0,0;nx,0,0,Knx;ny,0,0,Kny;0,0,0,0].
According to David Venditti, ψ2,ψ3 can still be known via special treatment.
However, since the first and last row of jacobian matrix is zero vector, I can not get ψ1,ψ4 .
There must be something wrong in the above deduction, could you kindly point it out for me? Many Thanks.
Ashkaari is offline   Reply With Quote
Old   May 30, 2014, 03:42
Ashkaari
The flow and adjoint solver utilize a median-dual finite volume scheme.
According to Oliver Amoignon, discretization of the adjoint equations become:
[(әR/әW)Tψ]i=∑(әRij/әWi)T*(ψj-ψi)/2+(әRib/әWi)ψi,
and j stands for nodes share the same edge with node i.
Rib will only be used for boundary nodes.
For simplicity,artificial dissipation is not taken into consideration.
Rij=(fc,fv)*(nx,ny).
(nx,ny) is the outward normal vector on edge ij.
The notation fc,fv stand for the convective and visous terms of node i.
Old   September 5, 2014, 12:41
Francisco Palacios
fpalacios is on a distinguished road
Maybe you can take a look at SU2 (su2.stanford.edu) and related articles.
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Old   September 6, 2014, 11:12
Ashkaari
I believe I have solved this problem. To my knowledge, the continuous adjoint method was applied in SU2, thank you all the same.
Old   January 27, 2016, 20:05
Tommy Chen
Tommy Chen is on a distinguished road
Hi Ashkaari
How did you solve this problem ?
I'm also working on Ajoint method development
Tommy Chen is offline   Reply With Quote
adjoint solver, boundary condition, jacobian matrix
ribbed channel / simpleFoam / boundary conditions beeo OpenFOAM Pre-Processing 20 July 17, 2013 08:39
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Euler Equations Boundary Conditions Christian87 Main CFD Forum 0 April 5, 2013 13:51
Method for solving the adjoint equations fumiya Main CFD Forum 1 June 13, 2011 00:18
A question about discrete adjoint method Thomas Main CFD Forum 3 August 9, 2006 12:37
