May 31, 2014, 12:24 |
drag and lift coefficient!!!
eray
Rep Power: 11 |
I am analysing naca2412 3D model in fluent I get Cd=0.8 and Cl=1.5 airfoil chord lenght is 0.3708m depth1.9m projected area along flow is 0.38(m2) are these values make sense or not?? I cant find any experimental data for my simulation.
thank you |
May 31, 2014, 16:43 |
RacMat
Rep Power: 13 |
try using XFLR 5 to get Cl/Cd vs alpha and Cl vs alpha graph for the airfoil if you cant find the data
June 1, 2014, 05:41 |
What is the angle of attack? Cd looks high to me…
June 1, 2014, 07:07 |
eray
Rep Power: 11 |
its aoa is 7.25degree and it is twisted wing 1.9m, chord size is 0.3708m and this analysis is 3D model I think thats why it is seems too much!! Is it impossible value for wind turbine??
thanks |
June 1, 2014, 09:45 |
eray
Rep Power: 11 |
Why Cd value is too high (0.5-0.9) in my model? Could anyone give me some advice why is that?? I could also share my model here. Please help guys!!!!
June 7, 2014, 03:49 |
First of all, why did you use 0.38 as reference surface? If you wing size is 1.9*0.37 that would give you 0.7m^2…
June 7, 2014, 04:13 |
eray
Rep Power: 11 |
The chord lenght of the airfoil is not same between station 0-1.9. The chord lenght is 0.37m at first station and it narrows along wing the last station's chord lenght is 0.09m. So I calculated the projected area in fluent. Thats how I get the result which is 0.38m^2
June 7, 2014, 04:42 |
Do you have big separated regions in your wing?
June 7, 2014, 05:42 |
#9 |
eray
Rep Power: 11 |
June 7, 2014, 07:21 |
#10 |
Stalled regions.
June 8, 2014, 12:29 |
#11 |
eray
Rep Power: 11 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 05:18 |
airfoil lift and drag coefficient | amir_14 | FLUENT | 5 | January 1, 2013 08:30 |
Drag and Lift coefficient for diffusor | rego | STAR-CCM+ | 3 | May 7, 2012 18:05 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
drag and lift coefficient | Noé | Siemens | 5 | July 13, 2004 10:21 |
