June 1, 2014, 23:59 |
Martin Hegedus
Rep Power: 19 |
Jinny,
Inviscid, incompressible, steady state flow is irrotational (due to vorticity transport equation), therefore inviscid incompressible steady state Euler is potential flow. Once the bound vortex reaches steady state, vorticity is not shed into the flow field, and then drag goes to zero. However, numerical error causes the bound vortex to decay and therefore vorticity needs to be constantly shed into the field to maintain it (and the implicit kutta condition). If there is no error, then the bound vortex does not decay and eventually all the vorticity in the field is transported away. On this page is a grid refinement study of the NACA 0012 airfoil at M=0.5 and alpha=1.25. http://www.hegedusaero.com/examples/.../Vassberg.html. You can see that drag drops as the grid is refined. For the case of FLO82-HCUSP, drag basically approaches zero. AO_CFD has a more challenging time probably because of higher artificial dissipation. I assume the same is true for OVERFLOW. |
d'alembert paradox, drag force, euler simulation, inviscid flow, naca0012 |
Drag coefficient too high at flow around a cyclinder | Gunni | OpenFOAM Running, Solving & CFD | 17 | October 31, 2019 02:18 |
Inviscid Turbulent flow | Vino | Main CFD Forum | 11 | May 8, 2019 10:35 |
Nozzle flow simulation in inviscid and viscous | Cath | FLUENT | 0 | January 28, 2007 02:16 |
Inviscid flow solver | luca_g | OpenFOAM Running, Solving & CFD | 0 | December 21, 2006 12:55 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
