June 1, 2014, 15:22 |
SA Model - Flow over cylinder
Vino
Rep Power: 13 |
I am doing a turbulent incompressible flow simulation over cylinder at Re=10000. I am using SA model with out trip term. when i use nu_tilda/nu=3-5(recommended, but there is no limit on higher side) , I am getting my Cl & Cd results on the higher side. But when i use nu_tilda/nu=50, i am getting results matching with literature. Now my question is "Can i use nu_tilda/nu=50 or more for the simulation?" Thanks in Advance.!!! |
June 3, 2014, 06:36 |
shikhar
Rep Power: 16 |
hi vino
i am also working on turbulent flow simulation but for compressible flows. Can u give more details about your problem. I think u are workin in 2D, right? are u using C-grid or O-grid? what are all the boundary conditions you are applying for nutil? |
June 3, 2014, 11:01 |
Vino
Rep Power: 13 |
Yes. I am doing a 2D simulation over a cylinder using O- type grid. At inlet & farfield, nutilda=3 nu At wall, nutilda=0 At outlet, nutilda extrapolated from interior domain |
June 4, 2014, 02:00 |
shikhar
Rep Power: 16 |
hi again
I am solving navier-stokes equations for flow over an NACA 0012 airfoil with C-grid. I am also facing problems in getting the right solution using SA-model. I think I am not applying the right boundary conditions. Can u explain me how you interpolate nutil at outlet from interior domain??? I am also not very clear about answer to your question. but i think if u try one more test case say an airfoil with same BC's and still getting right answer then probably using nu_tilda/nu=50 in your case may be right. |
June 4, 2014, 14:00 |
Vino
Rep Power: 13 |
I am using dummy cell type B.C , for example nutilda[i+1]=nutilda[i] at outlet
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Turbulence model / Boundary layers on a cylinder (VIV with 2DOF) | peatmac | FLUENT | 3 | April 16, 2012 14:23 |
Baldwin-Lomax model in wall jet flow | K.S.Chang | Main CFD Forum | 0 | December 7, 2005 01:51 |
