Default Stream function - vorticity boundary conditions for Couette flow
Old   December 24, 2019, 10:43
Default Default Stream function - vorticity boundary conditions for Couette flow
pelkeini
melkwin is on a distinguished road
I want to solve Couette flow without pressure gradient using stream function - vorticity formulation.
I need two boundary conditions for each plate Krogerfeedback.com.
I know that velocity and stream function values are zero on lower plate. Also, for the upper plate, the derivative of stream function equals to the velocity (U).
I need one more boundary condition.
Which boundary condition should I use for the upper moving plate?
melkwin is offline   Reply With Quote
Old   December 24, 2019, 11:31
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I need two boundary conditions for each plate.
FMDenaro is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
