CFD programming tricks?
Old   August 13, 2007, 09:34
Default CFD programming tricks?
Jimmy
Recently I've been reading the CFL3D 5.0 manual.On page 273. I found a problem that comfused me:The last 7 lines says that for nonlinear turbulent models,one has to add the additinal nonlinear terms to Reynolds stress Tau(ij) in the momentum equations,it's quite reasonalbe.However later it says miu*Laplace(k) (k is turbulent kinetic energy)should also be added to energy equations,why? It doesn't make sense.Is it because that 5.0 edition of CFL3D uses thin layer approximation so that this additonal term should be considered?If I has to modify this code for full N-S computation,how should I deal with these additional nonlinear terms? Thank you for your reply.
How to learn programming a cfd code? Peter Specht Main CFD Forum 6 April 27, 2004 17:12
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 September 13, 2000 04:48
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
