Comparing Experimental and Computational results. |
September 27, 2007, 12:08 |
I am trying to compare experimental results of a Mach 2 jet with nozzle pressure ratio(NPR) = 1.2 with the computational results , my problem is : 1) Say the freestream Mach number is 0.05 what values of pressure, temperature do I use in order to initialise the computational flow field? 2) Given the jet exit conditions (M=2 and NPR=1.2) how can I calculate the static temperature and static pressure values ?
Thank you |
Experimental data mapping. | paka | OpenFOAM | 5 | January 13, 2011 16:27 |
Visualizing/comparing experimental to computational results | f-w | Main CFD Forum | 0 | May 29, 2009 16:36 |
computational domain & boundary condition | novice | Main CFD Forum | 0 | May 8, 2006 19:30 |
Verifying fan test results with CFD | Jenny | FLUENT | 0 | January 17, 2006 00:52 |
experimental /any result of round jet in a co-flow | Lakshmi Kanth | Main CFD Forum | 3 | September 26, 2005 13:03 |
