multiblock - parametric edge
Old   October 28, 2007, 05:11
Default multiblock - parametric edge
amaury
I am using ICEM to mesh diferent drive system for 60'open. I am using multiblocks technics. In ICEM the default edge function is the bigeometric one. Is that because it is better to have a higher resolution at the junction between blocks (may be for the solver and the way it handle multiblocks grid)? Or is it because usually you split your blocks at some critical places (junction of surface, sharp corner...) and that it is necessary to have a better resolution there? Or is it just a random choice and it is not more of interest to use bigeometric?
Thank you and have a nice week end
Amaury
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 01:07
