Flux calculation using Riemann Solvers for non-Cartesian grid.!
Old   November 10, 2014, 17:46
Default Flux calculation using Riemann Solvers for non-Cartesian grid.!
Vino
Vino is on a distinguished road
I would like to clarify how to calculate flux at the interface using Riemann solver (say HLL) for Euler equation(2D). I am able to understand the flux calculation method for 2D-cartesian grids. In case of non-Cartesian gird, can someone tell me how to calculate the flux? Is the formulation correct which I have shown below for Riemann solvers(for any non-Cartesian edge)?
F1= rho*Un
F2=rho*U*Un+p*nx
F3=rho*V*Un+p*ny
F4=rho*E
(U-x velocity,V-y velocity, Un-velocity normal to the edge)
or
Do I need to calculate like this?
Calculate Un and Ut
Then calculate flux using Un & Ut
F1= rho*Un
F2=rho*Un*Un+p
F3=rho*Ut*Un
F4=rho*E
then convert it back to original coordinate as follows
F1=F1
F2=F1*nx-F2*ny
F3=F1*ny+F2*nx
F4=F4
Whether these both are same? Do both hold true for flux calculation using Riemann Solvers?
Thanks in advance.!!!
Vino is offline   Reply With Quote
Flux calculation in vertex-centered finite volume. Martin Main CFD Forum 3 June 4, 2008 10:04
cartesian grid generation method Abu Taleb Main CFD Forum 7 April 14, 2001 09:49
Cartesian grid generation method Abu Taleb Main CFD Forum 0 April 8, 2001 12:03
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
Non-uniform grid calculation Aspens Main CFD Forum 1 February 23, 2000 14:15
