oscillating airfoil in an inviscid fluid flow
Old   December 8, 2007, 02:15
Default oscillating airfoil in an inviscid fluid flow
S.T
How can we apply pressure boundary condition on airfoil surface oscillating in an inviscid fluid flow?
Old   December 8, 2007, 05:30
Default Re: oscillating airfoil in an inviscid fluid flow
Alex
Why do you need a pressure boundary condition, not the standard vanishing normal velocity on the airfoil?
Old   December 8, 2007, 06:36
S.T
I want to solve unsteady Euler equations using C-type mesh. that's why I need pressure boundary condition on the airfoil surface.
Old   December 8, 2007, 11:53
Peter Attar
the pressure BC can be obtained from the expression(latex math): {\partial p \over \partial n}=-\rho \vec{a}_b \cdot \vec{n} where \vec{a}_b is the acceleration of the body and \vec{n} is a vector normal to the surface.
Old   December 10, 2007, 01:17
S.T
the equation you mentioned must be applied in the fluid and we know that fluid particles slip on the airfoil surface and for slip condition we know that acceleration of body is not equal to fluid particles !
Old   December 10, 2007, 05:25
CFD Student
http://aiac.ae.metu.edu.tr/db/serv.p...=AIAC-2007-017
this might help you...
Old   December 10, 2007, 08:07
Peter Attar
You apply this to get the pressure and then a condition on the normal velocity(ie that they are the same for the fluid and structure). Look at any papers which deal with fluid-structure interaction and the Euler equations.
flow around an airfoil Nicola FLUENT 1 August 15, 2013 19:31
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Inviscid flow solver luca_g OpenFOAM Running, Solving & CFD 0 December 21, 2006 12:55
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
