December 18, 2007, 19:25 |
Y PLUS VALUE FOR AEROFOIL FLOW
What is the Y plus value i should use for running an aerofoil simulation at very high Reynolds number?
December 19, 2007, 05:37 |
Re: Y PLUS VALUE FOR AEROFOIL FLOW
it all depends on what turbulence model you use and whether you use wall functions or not. It will generally have to be either less than 5, or even less than 1 (e.g. S-A) or between 30 and 100 (when using wall function, say with k-e). NB Always try to avoid the buffer layer (5<y+<30).
December 24, 2007, 04:34 |
Why is buffer layer avoided?
January 7, 2008, 04:04 |
In generall, turbulence models are designed to work either in the logarithmic layer (where empirically based wall functions can be used to estimate the boundary layer profile near the wall)or in the viscous sublayer (where a fine mesh is used to resolve the layer) but not in the in-between buffer layer, where the effects of molecular viscosity and turbulence are of equal importance.
for more info look into your solver's manual under near wall modelling. |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
